PCMforless Adapter to ECM?
Old Jan 25, 2012 | 06:08 AM
armybyrd's Avatar
armybyrd
Default PCMforless Adapter to ECM?
I got my chip from pcmforless for my '88 and I took the little cover thats held on with two 1/4 bolts off and tried to get it to fit, now I unclipped the blue piece that was in the stock ecm and the pcmforless one plugs right in its place but is this rest of the adapter supposed to just hang out or?
Old Jan 25, 2012 | 06:54 AM
vetteoz's Avatar
vetteoz
Usually the stock memcal is attached to the side of the adapter holding the new chip.
requires opening the ECM case to fit inside
See
http://support.moates.net/author/darren/
Old Jan 25, 2012 | 06:58 AM
armybyrd's Avatar
armybyrd
From there is it the blue part that plugs into the ecm? What exactly do you mean by opening the ecm case? Do you mean leaving the little window part off or?
Old Jan 25, 2012 | 07:13 AM
vetteoz's Avatar
vetteoz
did you read the instructions I linked?
Cover will only fit if you have a low profile socket.
I don't know what style PCM4less use on their adapters
The instructions show fitting the adapter and stock memcal through the access hole,
I have always found it easier to open the ECM up to fit it;ie take the case apart
Old Jan 25, 2012 | 08:57 AM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Here is how it goes together:
Old Jan 25, 2012 | 08:59 AM
armybyrd's Avatar
armybyrd
Sorry didnt see the link-thanks
Old Jan 25, 2012 | 09:00 AM
armybyrd's Avatar
armybyrd
Thanks for the high speed pics Kubs!
Old Jan 25, 2012 | 09:12 AM
1allspub's Avatar
1allspub
Out of curiosity... what does one of these custom chips from PCMforless cost?
Old Jan 25, 2012 | 09:17 AM
LD85's Avatar
LD85
On my 85, it stuck out
Old Jan 25, 2012 | 09:26 AM
steven mack's Avatar
steven mack
Default adapter
You can fit the adapter and chip in the access port but you will have to remove the blue cover on the stock memcal chip.
Old Jan 25, 2012 | 09:39 AM
oldalaskaman's Avatar
oldalaskaman
totally excellent
Old Jan 25, 2012 | 10:53 AM
THE 383 admiral's Avatar
THE 383 admiral
I like my conversion better. you desolder the eprom... Solder in a zif socket.. and use a faster eeprom
Much easier to remove
Old Jan 25, 2012 | 11:09 AM
armybyrd's Avatar
armybyrd
Basic mods was about $150.
Old Jan 25, 2012 | 12:22 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Not bad $$ for supporting a car over 25 years old.
Old Jan 25, 2012 | 12:24 PM
Kubs's Avatar
Kubs
Originally Posted by oldalaskaman
totally excellent
I believe after you buy all the equipment if you change the car and need another tune to update for the changes its only $50 or something like that. The most expensive part is the initial purchase.
To PCMforless Adapter to ECM?
