Ghost in the machine!!!!
Old Jan 25, 2012 | 06:08 PM
captained230's Avatar
captained230
Default Ghost in the machine!!!!
I have a '94 LT-1. Every morning while driving to work between mile 8 and 9, the car dies. No spark. Wait 5 mins and it will fire right up and I can drive it the rest of the 35 miles to work and back with no problems. It has a new distributor, coil, and ignition control module. The security light does not come on when you try to start it right after it dies, so it should not be the VATS system. This is driving me crazy!!! Any help would be greatly appreciated.
Old Jan 26, 2012 | 07:56 PM
1986coupe's Avatar
1986coupe
Does it do it if you simply let the car warm up in the driveway?
How are the grounds in the engine bay?
When you put a new distributor on did you put a new water pump on? No leaks at the waterpump?
How is the connection from the coil to the distributor?
Old Jan 26, 2012 | 08:00 PM
leesvet's Avatar
leesvet
VATS does not kill a running engine..ever under ANY circumstances.
Has the fuel filter / pressure been checked with a gauge?
battery connectios at starter, wires to jumper (if equipped) and the ground bundle on the block...all 5 wires.
Old Jan 26, 2012 | 09:38 PM
C409's Avatar
C409
........... Does that mean you can drive in the car pool lane ??? ...
Old Jan 27, 2012 | 09:18 PM
captained230
Car ran at idle for over 20 mins this morning witt no problems. Water pump is not leaking. Coil wire connections seem fine albeit it is original wire. Where is the 5 block ground located? I also have never changed the fuel filter. I have owned the car for over 6 years.
Old Jan 27, 2012 | 09:31 PM
1986coupe's Avatar
1986coupe
Change the fuel filter. It may or may not be the problem but it certainly can't hurt.
As suggested, check the wiring at the starter. If they are poor this can affect it.
Old Jan 27, 2012 | 11:15 PM
leesvet's Avatar
leesvet
Look under passenger door along the frame rail....follow the lines to the cover thats hiding the CAN type filter. BTW...its messy, be prepared.
Old Jan 28, 2012 | 06:47 PM
captained230
Is there any type of relay on the car that affects the ignition?
Old Jan 28, 2012 | 06:48 PM
captained230
What I am getting is no spark, I will ck the starter connections tomm. Is there any relay that affects the ignition?
Old Jan 28, 2012 | 08:31 PM
93Rubie's Avatar
93Rubie
Not that I'm aware of. I'd suspect the ignition control module, the typical symptom is ok cold then dies hot, if let sit, ok again. Seems to be rash of them as of late. I think I got one too...further testing is needed however. I can tell you what is NOT wrong with my car...
Try spraying down the ignition components with water while running hot and see if any arching occurs. FYI, NOT on the OPTI.
Old Jan 29, 2012 | 08:33 PM
captained230
I live in Gibson County, TN. There are no car pool lanes here. Got to go to Memphis for those. We do have BBQ joints to make yo belly full. We also have the cabin of the last home of Davy Crockett. Skullbone TN is also one unique place. Come visit, stay, eat and enjoy!!!
To Ghost in the machine!!!!
