Rear End Alignment Help
Old Jan 27, 2012 | 03:50 PM
96Barry's Avatar
96Barry
7th Gear
Default Rear End Alignment Help
Anybody ever done your own rear end camber adjustment? My left rear is wearing terrible with a noticeable camber lean in. Can I just adjust the cam bolt on the inner portion of the strut rod and make it a bit better? Any tips are appreciated.
Old Jan 27, 2012 | 07:28 PM
1986coupe's Avatar
1986coupe
Inspect your spring to make sure that it doesn't have stress cracks on one side and not the other. If the spring is broken, cracked, or weak it can cause uneven wear on tires.
Old Jan 27, 2012 | 08:26 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Yes you can. Mind that the adjustment will not be as accurate as that of an alignment shop.
If you lay a straight edge on the rim of the wheel from the 12 to 6 o'clock positions, you can measure the amount of camber angle. Crawl under the car and adjust the eccentric bolt to match the camber angle on the opposite side.
Do not jack the car and try measuring as this will change the measurements drastically. After making an adjustment drive around the block and remeasure. This might take a few attempts until the correct angle is determined/set.
There are many reasons to not attempt this procedure "under the shade of the old oak tree". Most importantly you may have damage or worn parts that are causing the problem. In which a qualified shop would be the best place to have a good inspection and proper alignment accomplished.
Old Jan 27, 2012 | 09:12 PM
oldalaskaman's Avatar
oldalaskaman
there are several tech and utube vids about how to do it. there's even a tech on this site for it.
Old Jan 27, 2012 | 09:27 PM
oldalaskaman
heres a good one , hope it helps
http://www.google.com/url?sa=t&rct=j...5gfki_x9JwrSuQ
Old Jan 27, 2012 | 09:32 PM
oldalaskaman
http://www.vettenet.org/align.html '
and a nother
Old Jan 27, 2012 | 09:37 PM
oldalaskaman
and my favorite
http://www.google.com/url?sa=t&rct=j...aglENqcq72fdsA
Old Jan 28, 2012 | 11:33 AM
tequilaboy's Avatar
tequilaboy
Just be aware if you adjust the rear camber, this will also affect the rear toe or thrust angle.
If the thrust angle changes at all, this will change the yaw angle of the chassis and most notably, the center position of the steering wheel as your moving down the road, so you will also need to correct the front axle toe to re-center the wheel at a minimum.
So if after adjustment, if the steering wheel is clocked to the right when rolling with hands off the wheel, and centering the wheel manually will cause the car to yaw to the left, you can compensate by setting the toe of both front wheels towards the right. Maybe 1/2 turn on each side of the tie rods in the appropriate direction and go from there.
The front toe is very easy to adjust. Just pop the hood and loosen the lock-nut and turn the tie rod in the appropriate direction and snug up the lock nut. Rear is not as easily accessible.
This will be an iterative process if you choose to do it yourself. Good luck.
A laser level and digital level comes in handy along with something to check the total toe.
Old Jan 28, 2012 | 02:20 PM
96Barry's Avatar
96Barry
7th Gear
Thanks for the advice everyone. The rear spring is badly weakened and breaking apart on the left side only. This no doubt is the reason that the left rear is sagging and showing negative camber. New spring time!! I was gonna try to adjust it anyhow but that bolt was too tight to budge. Time to break out the credit card for a spring and some lowering bolts and bushings then take it to a pro for a proper alignment.
Old Jan 28, 2012 | 02:58 PM
pmihaltian's Avatar
pmihaltian
Slingshot
You know you can probably pick up a used OEM spring in good shape for cheap at one of the Corvette salvage years. Check it out.
You can probably install it yourself and then get a good computerized alignment from a reputable local shop for around $100. Food for thought....
Old Jan 29, 2012 | 01:35 PM
martymcfly's Avatar
martymcfly
Default rear spring problem
I went through this about 6 years ago on my 85. The spring delaminated on the left side to the point that I was riding on the rubber stop. I ordered a new one from Ecklers. It took about ten minutes to install it. It was the easiest spring that I have ever replaced.
Old Jan 29, 2012 | 10:49 PM
383vett's Avatar
383vett
I use this camber gauge and toe gauge to do all my front and rear alignments in my garage.
Old Feb 2, 2012 | 06:53 AM
ddahlgren's Avatar
ddahlgren
If it changed from normal something is broken or badly worn out or your camber link bolts got loose. If you changed bad parts for good ones take it to a shop and get it done right. When you change the camber you will change the toe and thrust angle. While it can be done in your garage with some gauges and time it is hard to beat a laser alignment with a tape measure and string.
Dave
To Rear End Alignment Help
