Heater Control Valve
Old Jan 29, 2012 | 06:37 PM
golfnstuff's Avatar
golfnstuff
Default Heater Control Valve
My 86 Vette has a heater control valve in the lower line going to or coming form the heater core. The upper heater core line has a line that T's off and goes to the intake. Two questions; When does the valve operate and what's the purpose of the line going to the intake. I read somewhere that the valve only closes when the AC is on so as to bypass the heater core. The valve appears to be electrically operated but everything I've read and on other cars I've worked on it's been vacuum operated.
Old Jan 29, 2012 | 06:42 PM
vetteoz's Avatar
vetteoz
Is vac operated
and IIRC is intended to prevent heat bleed from the heater core when the A/C is on by stopping coolant flow through core
Like to rear of intake is air/ steam bleed from rear of heads
Old Jan 29, 2012 | 07:03 PM
golfnstuff's Avatar
golfnstuff
Thanks. Still trying to learn my way around the Factory Shop Manual for answers. If a description was in there, I couldn't find it. The bleed line hose to the intake has a small leak at one of the connections. Replacing it is pretty straight forward but I was curious as to its purpose.
Old Jan 29, 2012 | 07:17 PM
vetteoz's Avatar
vetteoz
At the risk of starting a argument if/when replacing heater hoses I would just delete it as many of us have done.
Allows use of reg heater hose; not OEM with the nipple.
Port for tube @ intake takes 1/8" NPT plug IIRC
Old Jan 29, 2012 | 07:25 PM
golfnstuff's Avatar
golfnstuff
Default Heater
No negative effect by plugging it?
Old Jan 29, 2012 | 07:50 PM
vetteoz's Avatar
vetteoz
GM engineers obviously thought there was a requirement for it
Many of the aftermarket TPI replacement intakes don't have provision for it
( or even the rear coolant passage it connects to)
and there is no mention of guys overheating engines with those intakes
Mine has been gone 8 years ( stock TPI )
To Heater Control Valve
