700R4
Old May 13, 2002 | 12:21 AM
Corvette0096's Avatar
Corvette0096
Default 700R4
I need to get some info on a 700r4. I was told by a guy that is local here that i should find one out of a 88 or newer car.More splines on the input shaft?Now will my 85 drive line fit in a 88 tranny?
Old May 13, 2002 | 12:27 AM
vader86's Avatar
vader86
Default Re: 700R4 (corvette0096)
i thought it was 87 when they went with the 30 spline :confused:
Its just a better transmission, doesnt fail quite as easy as an early one. Should fit fine.
Old May 13, 2002 | 12:30 AM
Corvette0096
Default Re: 700R4 (vader86)
Oops, your right..... Now how about my drive line will that bolt up? is it just the input shaft that has changed? All the eletricals the same?
Old May 13, 2002 | 12:42 AM
HWoods's Avatar
HWoods
You still should find an 88 or newer trans. GM improved the lubrication to several parts that were experiencing problems in 88, so find an 88. You may have to use the tail shaft off your stock housing and maybe the output shaft of the origanl tranny, but it will make for a better tranny using an 88 case.
Old May 13, 2002 | 10:28 AM
dgoodhue's Avatar
dgoodhue
Default Re: 700R4 (HWoods)
I am no tranny expert, but according to the Corvette Magazines I have read. I thought the 87 Corvette Tranny has all the Corporate 88 updates.
Old May 13, 2002 | 04:20 PM
Rick86's Avatar
Rick86
Default Re: 700R4 (dgoodhue)
I was told all Vette 700r4's were 30 spline. I have '86 and I just rebuilt the tranny myself and can confirm it was 30 spline, VIN on the tranny confirmed it was the original tranny. I'm not arguing the other upgrades. Which include valve body and pump.
Old May 13, 2002 | 04:38 PM
85z51vette's Avatar
85z51vette
Default Re: 700R4 (Rick86)
I'll second this entire post. I just had the R4 out of my '85, and it is a 30 spline unit.
To 700R4
