dana 36 question, thick or thin ring gear
Old Feb 1, 2012 | 10:16 PM
nickpe's Avatar
nickpe
Default dana 36 question, thick or thin ring gear
i have a 1985 with auot trans and stock dana 36 with 308 gears. i was told that there is a thick and thin ring gear. in the 36 and you must match the gears with the carrier . i have a chance to pick up a set of 355's, thick ring gear. is my stock ring gear a thick or thin. what fits what. can i find out with out taking the rear apart
Old Feb 1, 2012 | 10:22 PM
rrt898's Avatar
rrt898
If I understand this correct.....the Dana with a 2:54 carrier has a thick gear and the dana with a 3:07 has a thin gear. I am sure somebody will post a better description...
Old Feb 1, 2012 | 11:12 PM
vetteoz's Avatar
vetteoz
have a chance to pick up a set of 3.55
You need a thin gear
Originally Posted by rrt898
..the Dana with a 2:54 carrier has a thick gear and the dana with a 3:07 has a thin gear. .
From the factory there are no " thick" or "thin "gears.
The thick or thin part only comes into play if you want to install new gears on a carrier
that originally had a different series gearset and you don't wish to install the correct carrier
to suit the factory (thin ) gearset that it is matched to
Exp
To put 3.XX gears in a diff that had 2.XX gears requires a thick AFTERMARKET gear set
To dana 36 question, thick or thin ring gear
