Large Tube runners.
Old Feb 3, 2012 | 07:14 PM
Iown1badvette's Avatar
Iown1badvette
Default Large Tube runners.
SO I have a set of AS&M runners 42mm I think and Im goin to replace my stock(ported ones soon). Need to know, will these work with the stock TPI base or should i get the Edelbrock TPI base? Are these huge gains? I have searched on a few websites headr positive things I'm just not familiar with these runners
Old Feb 3, 2012 | 07:25 PM
rodj's Avatar
rodj
Originally Posted by Iown1badvette
I have a set of AS&M runners Need to know, will these work with the stock TPI base
Yes
No because you are only as good as the weakest link so if the base does not flow as good as runners then little gained
Old Feb 3, 2012 | 09:05 PM
l98tpi's Avatar
l98tpi
Max G’s
The large tube runners will improve your power as well as move your power band up a little. Now obviously the higher flow intake manifold with the large tubes will give an even larger gain, but if you can or only want to do the runners at this time, they are worth it.
Old Feb 3, 2012 | 09:52 PM
cv67's Avatar
cv67
St. Jude Donor '05
If you can, get the aftermarket base ported nice gains to be made there on top of the runners imo.
Old Feb 3, 2012 | 11:11 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
It's not really a black and white question. There are some intakes where you could lose a bit of your low-mid range while gaining lots of HP. OTOH, with larger longtubes, you'll be gaining everywhere from idle on up.
Just not THAT much.
With tubes alone, I'm thinking the avg gain is about 15hp. That's up top. But, you'll also feel a bit more umph in lower rpms.
With tubes and aftermarket base, the gains jump to the 25hp range. I think the common feedback is 2-2.5 seconds with this modification.
FWIW, the TPI shootout comparison used a honed stock back with various tube changes. Because I didn't think there was THAT much material to remove from the stock base, I always believed the tubes were more important.
Then I heard more and more about the FIRST setup. It's base is the one with much better transitions into the heads. So, as far as large-tube bases go, I'm not terribly impressed with them. But, I would consider tubes if that's all ya got to run.
Old Feb 3, 2012 | 11:39 PM
soprano-90's Avatar
soprano-90
Hi I also came across a set of big tube runners got them them cheap! to put on my 1990, what do you mean by base? change the intake? or manifold , thanks?
Old Feb 4, 2012 | 12:11 AM
rodj's Avatar
rodj
Intake / manifold / intake base; whatever you want to call it.
The lump of alum that bolts to the heads that the runners attach to
Old Feb 4, 2012 | 02:06 AM
GREGGPENN's Avatar
GREGGPENN
Spider sucker, air ramp, big metal thingy, box springs, air pump humps, engine hat, tube roots, foundation location, nasal passage, and my favorite.....
Injector bung dungs.
Old Feb 4, 2012 | 07:11 AM
WW7's Avatar
WW7
This is the setup Im currently running on my 383 stroker motor. Edelbrock base, Accel runners , and a Mega ported plenum from "Corvette Plenums". I really can't say how much better it is then stock, because I installed it on the motor when the motor was new.. I can however tell you that I can rev this motor about 400 rpms higher then the stock motor could go with the stock intake.. Im sure a Super ram or a Mini ram would be much better but I wanted to retain the stock look..I also reamed the tubes out a bit ( more to clean them up) and enlarged the base a small amount.. Remember, this is on a 383 with a mild cam and bigger heads, so on a stock motor there should be a more noticeable improvement..The stock base will work, but there will be a gain with the Edelbrock base......WW
Old Feb 4, 2012 | 08:45 AM
Iown1badvette
Stupid question will i be better off buying a new set of stock runners to keep my low end torque or will these AS&M runners w/ the ported base increase torque?
Old Feb 4, 2012 | 08:52 AM
rodj's Avatar
rodj
Originally Posted by WW7
T. Im sure a Super ram or a Mini ram would be much better but I wanted to retain the stock look.
I went from similar ported big tube setup on my 383 (ZZ409 cam ) to a HSR and picked up .4
in the 1/4 with no other changes
Revised tune got another .10
12.7 w/ TPI - 12.2 w/ HSR
Old Feb 4, 2012 | 12:37 PM
GREGGPENN's Avatar
GREGGPENN
You won't lose any torque. You should gain some. Just not leaps and bounds using this as your only mod.
You might not be impressed over the change vs the value of the runners. In fact, at some point you might decide to put (cheaper to obtain) OEM units back on and selling the increasingly rare large tubes.
Old Feb 7, 2012 | 07:43 PM
Iown1badvette
WW7 thanks so much for that info the guys lives 10 min from my house an he can do it haha, im lookin into the edelbrock base, are removing the fuel injectors a pain?
Old Feb 7, 2012 | 09:06 PM
WW7's Avatar
WW7
Once everything is apart the injectors are fairly easy. When putting them back in be sure to get new O-rings for the injectors and for the fuel rails, if the ones in there are original they are pretty old.. When putting the injectors back in be sure to lube the O-rings with Vasaline to make them go in without rolling over and causing a leak..Also I found the best way is to put them in the fuel rail first , then line them up and push them into the intake manifold holes..Be sure to hook up the fuel lines and test for leaks before installing the runners and plenum..Nothing worse then assembling everything, then finding out you have a leak.....WW
Old Feb 7, 2012 | 10:06 PM
cv67's Avatar
cv67
St. Jude Donor '05
The 1 in siamese and putting a shine on the first in or so of the runner (that C.P. does) entry will do 0 for you except drain your wallet; sorry, its the truth
You want to get a good 3 out of that wall then seriously port the entire runner end to end all the way through;gotta really dig into the casting some
Base, too otherwise just bolt it all together and run it.
To Large Tube runners.
