oil preasure switch
Old Feb 6, 2012 | 02:23 PM
hitmanpty's Avatar
hitmanpty
Default oil preasure switch
I like to know where is the oil preasure swich. If any body have picture it will be super. just to make sure.
I need to know because my car have an aftermarket oil preasure gauge instal on the left side of the motor. and
since I know this switch have something to do with the fuel pump back up energy supply. I will like to install the proper switch. to restore the original condition.
Old Feb 7, 2012 | 04:06 PM
hitmanpty's Avatar
hitmanpty
I all ready found my aswer
Old Feb 7, 2012 | 04:26 PM
3D87C4's Avatar
3D87C4
Won't be long before you're answering more questions than you're asking.
Old Feb 7, 2012 | 08:09 PM
hitmanpty's Avatar
hitmanpty
I havent had the time to go to the vette and check the oil preasure switch. But i have a picture of the area. And i just dont see a preasyre swicht. Or nothing like it.
Old Feb 7, 2012 | 08:20 PM
383vett's Avatar
383vett
Above the oil filter.
Old Feb 7, 2012 | 08:27 PM
hitmanpty's Avatar
hitmanpty
Here is a pic of the area. In my manual it say it located under the distributor
[IMG][/IMG]
Old Feb 7, 2012 | 08:31 PM
hitmanpty's Avatar
hitmanpty
In the shop repair manual page 8A-201-2 figure B
Oil temperature sensor. Is located on top of fuel filter
Oil preasure sender is located under distributor driver side
Oil preasure switch also located under distributor cap
Love to post the page but i have The info on a usb memory stick. And at this time iam using my wife apple ipad. And this thing dont have a usb conection. I have to get some kind of adaper for tha.
That is why ipad is going down android is the future
Old Feb 7, 2012 | 08:43 PM
vetteoz's Avatar
vetteoz
You have these two units
mounted here ( in place of the later model single unit shown)
Old Feb 7, 2012 | 08:53 PM
3D87C4's Avatar
3D87C4
Did a search, any of these help?
http://forums.corvetteforum.com/c4-t...re-sensor.html
http://forums.corvetteforum.com/c4-g...ease-help.html
http://forums.corvetteforum.com/c4-t...t-is-that.html
http://forums.corvetteforum.com/c4-t...-location.html
Old Feb 7, 2012 | 08:54 PM
hitmanpty's Avatar
hitmanpty
Thank you that it.
Yest but i just dont see on my picture. I guest iwill have to go to the car an see if some one remove it. Or for some extrange reason my car did not came with that
Old Feb 7, 2012 | 08:58 PM
LD85's Avatar
LD85
Yes, next to the distributor, oil temp is down lower
Old Feb 7, 2012 | 08:59 PM
weaselbeak's Avatar
weaselbeak
Here's where mine is although it's possible to have it at a different location on your block.
Old Feb 7, 2012 | 09:09 PM
hitmanpty's Avatar
hitmanpty
Thankx
hitmanpty's Avatar
hitmanpty
Old Feb 7, 2012 | 09:34 PM
vetteoz's Avatar
vetteoz
Won't see much
If you can't feel it under dist from top then going to have to take dist out
Note.
You own a C4.
Get used to operating by FEEL because there are plenty of things you can't see without dismantling the car
Switches are in same location on all C4's ( configuration varies by year )
Yours has non stock fittings
Old Feb 8, 2012 | 04:15 PM
hitmanpty's Avatar
hitmanpty
Won't see much
Note.
You own a C4.
I think i will try to remove the wipper motor first. Since i habe to reper tha too any eay
Old Feb 9, 2012 | 09:17 AM
hitmanpty's Avatar
hitmanpty
ok i just when to my car last night. and took a look. and the oil preasure and oil sender are there. so no problem with that no more
thank every one for the help
To oil preasure switch
