Sensor/switch on pass side between rear sparkplugs
Old Feb 6, 2012 | 05:53 PM
Tim_Ko's Avatar
Tim_Ko
Default Sensor/switch on pass side between rear sparkplugs
RE: 1985 L98
I have a new used car and I was changing the sparkplugs and the wire connector cap crumbled. Then I looked and it was the top of the sensor or switch or whatever.
I looked in the book and I couldnt find the info.
Does anyone know off the top of their head - the name of sensor. It had a single wire on it. It was located on the passenger side of the engine right there between the two rear sparkplugs.
What is that thing? Is it the knock sensor?
Old Feb 6, 2012 | 07:31 PM
aminnich's Avatar
aminnich
Coolant Temp Sender
Old Feb 6, 2012 | 08:18 PM
Tim_Ko's Avatar
Tim_Ko
Originally Posted by aminnich
Coolant Temp Sender
Huh ! I thought the coolant temp sensor was up on the front of the block above the water pump right by the inlet where coolant enters the tpi to heat it up. i remember seeing it when i did the coolant bypass mod.
I think the book shows the sensor up in the front as the coolant temp sensor. I'll check that again.
Old Feb 6, 2012 | 08:33 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Fan switch
Old Feb 7, 2012 | 12:41 AM
red89c4's Avatar
red89c4
i thought it was the oil temp sender ???? some one that KNOWS will need to verify.
Old Feb 7, 2012 | 12:53 AM
rodj's Avatar
rodj
Originally Posted by AGENT 86
Fan switch
http://forums.corvetteforum.com/c4-t...t-sensors.html
Originally Posted by red89c4
i thought it was the oil temp sender ???? s.
Why would the oil temp sensor be in the head that only has coolant passages ?????????
Oil temp sensor is in the block above the oil filter
Originally Posted by Tim_Ko
What is that thing?
Knock sensor is in the block ;directly below the sensor in the head you are talking about
Old Feb 7, 2012 | 06:54 AM
rithsleeper's Avatar
rithsleeper
I second coolant temp sensor. Take the wire off the sensor, touch it to the block and look at your dash. I think you will see that the coolant temp now reads 299. If not then its something else. My coolant temp sensor is in the block between 2 and 4. Pass side (or maybe that's 3and 5...)
Reason I know is my dip stick will sometimes wiggle and turn and hit it. Then I freak out for a split second when I see coolant go to 299.
Old Feb 7, 2012 | 07:08 AM
rodj's Avatar
rodj
OP has a '85
And your year model is ........................
http://forums.corvetteforum.com/1579925755-post10.html
My coolant temp sensor is in the block between 2 and 4. Pass side (or maybe that's 3and 5...).
Actually it is between #6 and 8
#3 and 5 plugs are on drv side
Old Feb 7, 2012 | 07:53 AM
Tim_Ko's Avatar
Tim_Ko
Fan switch
Rod, that's a good link. Thank you.
Thanks guys. I appreciate all the input. I'm trying to change my technique from "throwing money at the problem" to finding the problem and then buying "the right" parts. All this help gets me pointed in the right direction.
Thanks again
Tim
Old Feb 7, 2012 | 08:26 AM
WW7's Avatar
WW7
I'm trying to change my technique from "throwing money at the problem" to finding the problem and then buying "the right" parts. Thanks again
Tim
Throwing parts at a problem can get expensive real fast, especially when your dealing with a Corvette....WW
Old Feb 7, 2012 | 09:16 AM
red89c4's Avatar
red89c4
you are correct rodj, i didnt think that out to wel
Old Feb 8, 2012 | 04:43 AM
blackozvet's Avatar
blackozvet
Hi tim, i replaced the fan switch on my 85 with this one and it works well
http://www.summitracing.com/parts/JET-60600/
To Sensor/switch on pass side between rear sparkplugs
