Head gasket reccomendations?
Old Feb 8, 2012 | 01:13 AM
Yguy's Avatar
Yguy
Default Head gasket reccomendations?
I'm probably going to pull my heads off for porting later this year. When I put them back on I'd like to use a good head gasket that's going to last like my OEM's have but I'm hoping to use a gasket that'll have a thinner compressed thickness as well so's I can increase my compression a bit. And yes, I'm planning to use new head bolts.
Old Feb 8, 2012 | 07:06 AM
oldalaskaman's Avatar
oldalaskaman
your best bet would be the gasket recommended by the person doing the machine work
Old Feb 8, 2012 | 02:21 PM
desertmike1's Avatar
desertmike1
Felpro.
Old Feb 8, 2012 | 02:52 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Feb 8, 2012 | 03:01 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Cometics are the "Cadillac" of head gaskets. Pro Comp might still be making a knock-off -- which might be an option. I used actual Cometics -- as recommended by my builder.
They come in varied thickness, but the final determination would come from your head condition.
Victor Reinz .026 gasket is often recommended for our stock vettes. With the stock .025 piston-in-hole depth and chamber size, the .026 gasket gets you closest to proper quench.
Even if you shave off .01" to clean up heads.
Old Feb 8, 2012 | 11:50 PM
Yguy's Avatar
Yguy
Thanks very much for the input. Do you know of a source or p/n for the Victors?
Old Feb 9, 2012 | 12:41 AM
GREGGPENN's Avatar
GREGGPENN
To Head gasket reccomendations?
