Scanner or PC program?
Old Feb 15, 2012 | 10:17 AM
PG-LT4's Avatar
PG-LT4
Default Scanner or PC program?
Hi all
I’m looking for a “scanner” or PC program that will allow me to read codes but also make adjustments like to the cooling fans and so on.
Is there something like that out there?
Old Feb 15, 2012 | 10:30 AM
cumbercr's Avatar
cumbercr
A scanner is an OK tool for checking codes and verifying sensors. As far as making changes to the calibration file, you will want to go with a software product like Tuner Pro RT. Check the Moates.com site for the hardware and software you will need for your car.
Old Feb 15, 2012 | 07:04 PM
SunCr's Avatar
SunCr
Depending on your Cell - you might check Droid or Apple Apps. Cheap and Easy for any OBD2 car - don't have any use for an OBD1 so I don't know if there's an App out there for pre '96.
To Scanner or PC program?
