windows and vent fan
Old Feb 19, 2012 | 03:16 PM
seans85vette's Avatar
seans85vette
Default windows and vent fan
So after leaving my vette sitting for about 5 months (I know I know big mistake) I decided it was time put her back on the road. However while I was away some goblins crept inside and now neither the power windows or vent fan works. Ive already checked the fuses and they are fine...does anyone have any idea what the problem could be.
I'm thinking there must be a module that controls both (assuming that the problem is one and the same)
Old Feb 19, 2012 | 07:55 PM
1986coupe's Avatar
1986coupe
You will simply have to trace the wires to check for power at each. You are confident that the fuses are good? Did you look at them or test them with a multi-meter?
Old Feb 20, 2012 | 11:33 AM
seans85vette
yes and interestingly after I double checked the fuses today the windows started working again Hopefully they continue to work.
Which leads me to think the blower motor may need to be replaced to fix my other issue. I'm assuming this to be behind the dash, but does anyone know where about it is located?
Thanks in advance for any assistance.
Old Feb 21, 2012 | 09:00 PM
seans85vette
blower motor changed and still no air
Old Feb 22, 2012 | 12:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you have a meter, this info from my 86 FSM will help you find the problem.
http://members.shaw.ca/dankai/HVAC%20Electrical.pdf
To windows and vent fan
