What spark plugs do you use?
Old Feb 20, 2012 | 02:36 PM
GvilleFloridaC4's Avatar
GvilleFloridaC4
Default What spark plugs do you use?
I have a 93 C4 with 70k miles.
Mods: k&n filter, DRM 400 conversion ( p&p heads,cam,high flow springs/valve,headers,tb )
Right now I found out it had bosch platnum plugs in it and in my experince you never put a bosch plug in a chevy. Just whats worked for me.
Should I go with stock AC delco or somehting different with the things that have been done to the motor?
What are you using and how has it worked for you?
Old Feb 20, 2012 | 03:03 PM
flightmate's Avatar
flightmate
I have a DRM 480 that I believe has had AC Delco plugs in it from the beginning. I just replaced them this year with the same. No issues.
Old Feb 20, 2012 | 04:14 PM
STL94LT1's Avatar
STL94LT1
Ngk tr55.
Old Feb 20, 2012 | 04:25 PM
pmihaltian's Avatar
pmihaltian
Slingshot
I ran Bosch platinum plugs in my L98 for years and had very good experience with them. The car ran strong and never needed any repacements. A few years ago I changed them out for AC OEM plugs for NCRS judging purposes. It might be my imagination, but it seems to me that the car ran stronger with the Bosch platinum plugs in it. I still have the Bosch plugs and some day soon I think I'll put them back in.
FWIW
Old Feb 20, 2012 | 05:28 PM
srobertlaw2003's Avatar
srobertlaw2003
I know this is off topic but do you live in gainsville fl by chance?
Old Feb 20, 2012 | 05:34 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
autolite
Old Feb 20, 2012 | 05:50 PM
RichS's Avatar
RichS
NGK in everything.
Old Feb 20, 2012 | 06:21 PM
Vincentiroc's Avatar
Vincentiroc
E3's
Old Feb 20, 2012 | 08:02 PM
Sidney004's Avatar
Sidney004
Bosch Single Platinums
Old Feb 20, 2012 | 08:17 PM
higgyburners's Avatar
higgyburners
I believe in the Beer Fairy
St. Jude Donor '15,'19
NGK Iridium IX ( TR55IX )
Old Feb 20, 2012 | 09:48 PM
blkzr1's Avatar
blkzr1
Default spark plugs
FWIW, i used autolite plugs for many years. i had 4 plugs left from several years ago that were stamped made in USA. i went to the local parts store to get 4 more and noticed that they are not stamped any more, made in USA, but are now made in china. i called autolite and told them why i will no longer use their product. now, i am going to all ac delco plugs, still made in USA. just my 02. see ya
Old Feb 21, 2012 | 09:09 AM
WW7's Avatar
WW7
My suggestion is to run the plugs that originally came in the car. When I had my stock L98 in my 89 vette I tried different expensive plugs and came back to the stock AC Delco plugs because I noticed no difference at all in the more expensive plugs.. GM should know what works best , they built the car....WW
Old Feb 21, 2012 | 09:15 AM
rocknroller's Avatar
rocknroller
Very true.
Old Feb 21, 2012 | 12:33 PM
mtwoolford's Avatar
mtwoolford
Originally Posted by Vincentiroc
E3's
just put some E3's in my work truck; if they work out, thinking of putting them in my 96; what's your experience with E3's ?
Old Feb 21, 2012 | 01:04 PM
jimmymack's Avatar
jimmymack
St. Jude Donor '09 thru '25
Originally Posted by STL94LT1
Ngk tr55.
Old Feb 21, 2012 | 04:06 PM
Vincentiroc
Smooth acceleration, quick start ups
Old Feb 22, 2012 | 10:54 AM
Strick's Avatar
Strick
I have NGK TR55IX plugs. They have been in for 20K and two autocross seasons and still run excellent. If your engine doesn't use any oil and runs fine, go with an Iridium plug as they will last a long time. In the past, some guys have had bad luck with AC Delco professional plugs as they are double platinum and the pucks sometime fall off giving you a huge gap.
To What spark plugs do you use?
Old Feb 22, 2012 | 11:13 AM
Nathan Plemons's Avatar
Nathan Plemons
NGK TR55 or AC Delco R44LTS.
Old Feb 22, 2012 | 11:14 AM
VETTEHIGH's Avatar
VETTEHIGH
Originally Posted by PLRX
autolite
Old Feb 22, 2012 | 11:21 AM
engle1147's Avatar
engle1147
Bosch Platinum+4 plugs for several years now - no problems/issues to report.
