Boost issue?
Old May 14, 2002 | 06:37 PM
krivera's Avatar
krivera
Default Boost issue?
Ok this is kinda weird i never noticed it till i figured i would look at my boost gauge?? Ok i have a Auto TRanny...and 3:73 gears so i am at a light i floor it and my first gear hits 12 psi (mmmweird i have a 10 psi pully) i go into second gear 10 psi(ok that sounds right) Drive (5 psi) What happen :sad: and over drive (2psi) :cry just need your thoughts?? :reddevil
Old May 14, 2002 | 09:56 PM
snaketr's Avatar
snaketr
Default Re: Boost issue? (krivera)
What are your RPM's. Boost is made by the RPM's. If you are just cruising in OD you will not make much boost until the pedal goes to the floor and the RPM come up.
Old May 15, 2002 | 09:26 AM
LPDesRoche's Avatar
LPDesRoche
Default Re: Boost issue? (snaketr)
Boost is a byproduct of back pressure. The harder you are on it and the higher the revs the higher boost number. With the D-1 you are not going to make max boost until you are at the top of your power band.
To Boost issue?
