EGR Help please.
Old May 14, 2002 | 09:56 PM
scorp508's Avatar
scorp508
Default EGR Help please.
Ok guys, a bit of a dilemma here possibly. I don't know if 87 is a one-year design, but this is kind of a bitch. :)
Here we have the unsleeved 1987 EGR Tube.
Notice the new damn sleeve I bought from Ecklers isn't long enough. :rolleyes:
Notice there is only a flange on one end, and not on the other. '87 uses a clamp on the other end to attach it to the manifold.
Here we have a Hooker 2149 passenger side header. Notice the mounting for the EGR.
Now.... I know that 88 Vettes use the double-flange method, as Fastguy's 88 has it (I looked). What does 86 use?
It looks like I need to get myself a 88+ EGR tube at the tune of $88 or so dollars. Yippeeeeee!
So... what happens if I do this.
1. Put a blockoff plate on both the intake & header. Disconnect the EGR solenoid.
2. Put a blockoff plate on the header, leave the EGR tube hanging in the engine bay connected to the intake. Leave solenoid plugged in. (Lean condition from fresh air vacuum leak?)
[Modified by scorp508, 8:58 PM 5/14/2002]
Old May 14, 2002 | 10:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: EGR Help please. (scorp508)
Scorp, I just replaced my EGR tube with a new one from the General. It was $70list & $55 to me.
I still have my old EGR tube and it's in tact except that the Al foil is mostly gone from the insulation. If it ifts, you are welcome to use it till you feel you want to spring for a new one. From earlier shots or your top end it looks like it might fit; you'd need two more Torx bolts as I don't have any spares of that size.
Where in MA are you, close to Boston?
Old May 14, 2002 | 10:08 PM
scorp508's Avatar
scorp508
Default Re: EGR Help please. (65Z01)
I'm about 30 miles south of boston. Thank you. :) I think as of right now Fastguy is going to let me use the one off of his '88 for the time being. His is all hooked up, but he didn't drill out his headers so it isn't functional. I'm going to give him the intake blockoff plate for now.
Old May 14, 2002 | 10:11 PM
65Z01's Avatar
65Z01
Sounds like a plan. :cool:
Old May 14, 2002 | 10:15 PM
FlyboyZR1's Avatar
FlyboyZR1
Hey what's the purpose of putting one of those sleeves on the EGR tube anyway?
Old May 14, 2002 | 10:30 PM
65Z01's Avatar
65Z01
Default Re: EGR Help please. (FlyboyZR1)
Four spark plug wires are routed under that upper EGR tube. The tube insulation combined with spiral wrap around the wires provides protection from the heat. The wrap also assures that the exhaust gasses will be hot enough to trigger the EGR Temp. Switch in the upper end of the tube.
Also the shiny Al surface of the wrap is kinda pretty.
[Modified by 65Z01, 8:31 PM 5/14/2002]
Old May 14, 2002 | 10:42 PM
drive it's Avatar
drive it
And remember that if you do want to hook up the egr and have it work, you need to drill out the egr tube on the header! I figured it out after a while....
Old May 14, 2002 | 10:45 PM
scorp508's Avatar
scorp508
Default Re: EGR Help please. (drive it)
I've already done that with anticipation of running it.
Old May 14, 2002 | 10:54 PM
Rich B.'s Avatar
Rich B.
My '86 has the exact same EGR pipe as your OEM '87.
The '88-'89 Pipe, EGR Vlv part # 10055728 is $40.87 at GMPartsetc...
Old May 15, 2002 | 02:08 AM
MDred85's Avatar
MDred85
Hello,
This may be a stupid question, but do you need the EGR? The way it was told to me or at least the way that I understood it, the EGR was just an emissions device .
Thanks in advance.
MDred85
Old May 15, 2002 | 09:20 AM
Jim85IROC's Avatar
Jim85IROC
Default Re: EGR Help please. (MDred85)
Hello,
Thanks in advance.
MDred85
Massachusetts sniff's your tailpipe at 50mph on a dyno, so the EGR may be necessary with his cam to keep it under the limits.
Old May 15, 2002 | 11:57 AM
Rich B.'s Avatar
Rich B.
Default Re: EGR Help please. (Jim85IROC)
Part of the NYS inspection is a visual check for emissions equipment...OK if the inspector doesn't know it's gone... :D
...But you can never tell just how much they know... :crazy:
[Modified by Rich B., 11:19 AM 5/15/2002]
To EGR Help please.
