auxiliary fan switch
Old Feb 24, 2012 | 09:28 AM
steven mack's Avatar
steven mack
Default auxiliary fan switch
I need to know where the auxiliary fan sender is.Thanks,Steve
Old Feb 24, 2012 | 03:55 PM
1986coupe's Avatar
1986coupe
What year? On L-98 cars it is on the drivers side between #1 and #3 spark plugs.
Old Feb 24, 2012 | 05:10 PM
steven mack
It's an 88.The one on the drivers side runs the front cooling fans .The problem I'm having is ever since I bought the Vette the auxiliary fan would run all the time.Now since I put in a new motor I can't get the auxiliary fan to come on.Even if I jumper the relay harness.to the fan.I think I missed a ground wire somewhere.
Old Feb 24, 2012 | 07:48 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Booster fan relay connections
Terminal C-dark blue-12v from fan fuse
D-red-12v from battery
B-dark green/white-temp switch in head= ground when closed
A-black/red-fan motor +
Old Feb 24, 2012 | 08:32 PM
steven mack
Hi Dan ,I tried to jumper the wires you mentioned but the fan still won't turn on. I have the factory manual for my 88 which tells me which wires to jumper but still no luck.the fan worked fine till motor swap.do you think it could be a ground wire not connected.I put a new switch in the drivers side head and when the main fans come on if I disconnect the wire they shut off.It's really strange that the auxiliary fan would come on when ever I started the motor before the engine swap.The fan should come on when I turn the air conditioner on but it doesn't.
Old Feb 24, 2012 | 10:43 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Pull the connector from the Aux Fan sensor and ground it, with ignition On the fan should run.
If you open the small connector in the A/C line and start the engine the main fan will run but should not run just because you turn on the A/C.
Old Feb 24, 2012 | 10:54 PM
rodj's Avatar
rodj
So the aftermarket switch is bypassing the computer and controlling the main fan ,
what is controlling the Aux fan ?
At what temp does the main fan run?
Are you the original owner?
Someone may have done the common mod that wires main fan to Aux fan switch so both run at same time
Old Feb 25, 2012 | 08:43 AM
AGENT 86's Avatar
AGENT 86
You say "they shut off". Are both running ?
Have you tested(meter) the inputs and output of relay to see if they are correct ?
Old Feb 25, 2012 | 09:08 AM
steven mack
Thanks for the input guys.I thought the previous owner may have rigged the main fan to come on all the time. the Vette came from Texas pretty hot there.Dan only the two front fans come on.Before engine swap I could ground the temp switch and the fan would come on.I am thinking of putting the old switch back in and see what happens.I also may try another ECM I have.The front fans come on at 235 degrees.I am going to check the wires again today Dan.Once again thanks for the input guys.Dan I forgot to mention That the hot wires to the relay are both working for both fans.I will also try and disconnect the small wire to the air conditioner and see if the auxiliary fan come on.
Old Feb 25, 2012 | 10:06 AM
tequilaboy's Avatar
tequilaboy
Hi Steven,
Gotta admit I'm sligthly confused by your posts.
The Aux fan is the front (pusher) fan. There should only be one aux fan in front. Approx. 235 F is the expected activation temperture via the switch in the drivers side head.
The main fain is the rear fan. Your bins are programmed for the following main fan on/off temps. (Both A/C on and A/C off settings are the same values).
199.84 On
184.47 Off
Main fan should be activated above 199.84 F or when the A/C high pressure switch is activated (open)
Aux fan should run when the switch in the driver's side head closes at approx. 235 F.
Old Feb 25, 2012 | 12:36 PM
steven mack
HI Patrick it's good to hear from you.I changed my motor back to the factory one and put the GM Hot cam in.I am running the stock chip without your adapter.I didn't want to over fuel the motor.I guess I had which fan was which mixed up.Do you think I'll be O.K. if I run the adapter with the lowest fueling chip you burned for me and turn the fuel pressure down.
To auxiliary fan switch
