Dimmer switch rod actuator
Old Feb 26, 2012 | 06:31 PM
csthews's Avatar
csthews
Default Dimmer switch rod actuator
I started looking into why my dimmer switch would not engage, when the rod actuator fell out. I've spent most of the afternoon trying to get it back in..(grease on the end cap to hold it in place) but with no luck. All the posts i've been able to find here mention removing the steering wheel. Is it possible to install the switch actuator without removing the steering wheel, or am I just wasting my time trying????
Old Feb 26, 2012 | 06:59 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I'm not sure if removing the wheel is necessary; what year Vette?
Old Feb 26, 2012 | 07:41 PM
csthews's Avatar
csthews
Sorry about that. It is a '95 LT1.
Old Feb 26, 2012 | 09:19 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
My headlight switch froze up a while back and replaced the switch and panel, got it on ebay.
Old Feb 26, 2012 | 10:21 PM
csthews's Avatar
csthews
The headlight switch is a bit easier since it is on the console and not part of that multifunctional switch that is installed on the steering column.
Old Feb 27, 2012 | 01:10 AM
Hooked on Vettes's Avatar
Hooked on Vettes
Your tilt steering column probably has a lot of side ways play caused
by the two pivot pin holes elongating/wearing out.
That causes the dimmer actuator to fall out of place. It lays against
the column right below the multifunction lever. It's hidden by the
plastic steering column shroud which holds it against the column.
Here's a picture of what the dimmer actuator looks like.
The arrow points to where the multifunction lever pushes down ward
on it to activate or deactivate the dimmer switch.
The red curve shows how the dimmer rod meets the actuator.
The 2nd picture shows the actual dimmer rod end which presses
against the actuator.
To put it back in place requires removing the air bag, steering wheel,
clock spring, multifunction switch and other parts until you can lift
up the lock housing cover assembly and slip the dimmer actuator
back in place behind the steering column shroud.
I've never tried it but tilt the wheel all the way up to create some
clearance. Unhook the rod from the dimmer switch. Try pulling
the dimmer rod down the column. Tape the dimmer actuator to
it. Then push it back in position.
There is a plastic cover piece that comes off of the back side/base
of the multifunction switch. If you remove that you might be able
to see the position of the dimmer actuator as you push it back in
position.
If it happens again you'll need to address the pivot pin problem or
keep the tilt wheel in the straight position.
Old Feb 27, 2012 | 10:35 AM
csthews's Avatar
csthews
Thanks for the post. I've tried sticking the actuator to the end cap using heavy grease. Never thought of attaching it to the rod. I'll give that a try. Once again, thanks.
Old Mar 4, 2012 | 07:24 PM
csthews's Avatar
csthews
"Hooked On Vettes" Thanks a million for the pic of how the actuator fits on the rod. I used a mirror to figure out how the other end fits up into the column. Using a little duct tape and a lot of patience I was able to get the actuator back in its place. I now have hi beams. Thanks again....saved me over $300 bucks (what the shop would have charged to replace it) since I don't feel comfortable removing the airbag.
Old Jun 12, 2016 | 07:11 AM
RayTremblay's Avatar
RayTremblay
Oh my God, Thank you thank you thank you. This is just what I was needing. Now I guess it's time to go to work....lol
Old Oct 5, 2016 | 08:08 PM
whobub's Avatar
whobub
Revisiting this also....
Model: 1993 C4 LT1
On removing the multi-function switch....Is this supposed to be the pain that it seems to be to get it out of the "Lock Housing Cover"???? As they do, the FSM puts it so "simply" stating (p. 3F3 of 1993 FSM, book 1) "Pull toward driver door to release detent/multifunction turn signal lever".
Suuuurrrrrrrreeee.....thus far I've pulled on it where it was near a breaking point. And THIS must be done prior to completing Sub Section B "Housing Cover" removal (p. 3F5B-9 of that same FSM). I'll attempt to upload a picture from the FSM--the view is as seen from the instrument cluster. When I preview this post, it appears to be sideways and I modified it to be the right way before uploading it.
So I have the 'accuator' in my hand, but only after it fell out as I loosened the lock housing cover. It sure would be easier if I could get that multi-function switch off to fully see what I'm doing.
Old Oct 5, 2016 | 10:00 PM
csthews's Avatar
csthews
Assuming the 93 and 95 are similar, you can't remove the switch without removing the steering wheel first. You can remove the steering switch lever by pulling it out. It should pop out like the FSM said. But, at the risk of damaging the switch and making your job much more difficult, I would not recommend trying to force it out. Besides, just pulling out the lever does not help with reinstalling the switch rod actuator.
Old Oct 5, 2016 | 11:37 PM
whobub's Avatar
whobub
But I DO have the steering wheel off, all the way down to removing the ignition switch and all that it entailed. I absolutely need to get that multi-function switch (hereafter the MFS) off in order to get the Lock Housing Cover off so that I can have a clear shot at getting the 'actuator' properly installed.
The FSM over simplifies things as usual. I just can't figure out what sort of "detent" they speak of when pulling 'toward the door'--I've tried push-pull at the base of the MFS, twist, lefty-loosy, righty-tighty,even put my little finger in my ear and jumped up and down at sundown. Nothing!!!!
Anyone ever gotten this out without breaking it? It is a GOOD, functional (currently) switch and I don't want to damage it by doing the wrong thing. I need to re-use it as I don't have another $200+ to get a new one of these if I break it.
Thanks to all for input.
Old Oct 6, 2016 | 06:02 PM
csthews's Avatar
csthews
I have pulled mine out. Just grabbed the lever and pulled really hard and it popped out. Then I realized it didn't help to have it out, so I put it back in.
Old Oct 14, 2016 | 02:05 PM
whobub's Avatar
whobub
Thanks. I did just that (reluctantly) and it came out, but did feel like it was going to cause something bad. All was well however. As another poster alluded to, it didn't really have to be pulled to get to the hi beam actuator, but in my case it was useful to get a better view of that area without having to pull off the entire steering column shroud/cover.
I wanted to share with MY solution with keeping the dimmer 'rod' and actuator in place whilst putting everything back together. I've read everything from others putting more grease and duct tape on it to hold it in place. Not wanting to attempt that, I put in place a neat trick I utilized while working on the tight confines of a Harley V-Rod. Dental Floss! That's right, preferably the unwaxed kind to make a more secure knot when the time comes.
There DOES have to be some mitigation in keeping that extremely light piece of plastic (actuator) together while holding it to the 'rod'. When referencing my attached pictures, please note "HookedOnVettes" contribution of great pics on the actual rod & actuator--these were nice and clean--your mileage may vary as mine was FULL of grease and I couldn't even recognize there was the rod there at all at first.
As the pictures I took of the process will depict, the reader should note that a piece of floss was tied to the 'rod' and the connecting end of the plastic actuator (holding it to the rod)--go ahead and tie a knot on this one as it will be key in keeping the top/bottom secured to the actual dimmer rod. Another piece of floss was looped through the opening in the "front" of the plastic actuator so as to allow it to be pulled through the steering column components and the opening near the front (closer to the where the steering wheel will be).
Sorry I was unable to edit or outline the parts in some way, that's why I want you to reference the aforementioned nice pics from 'HookedOnVettes". When I went to "preview post" this side showed it as needing a "right rotation". Again, sorry if this is what you also see, but I DID upload them properly orientated as a 'side view' of the steering column.
If you would like the full series of pics that I took of this process (8 in total I believe), feel free to PM me and I'll forward them onto you.
I need to wrap so I hope I didn't forget anything in my hurried prose.
Old Oct 14, 2016 | 10:21 PM
csthews's Avatar
csthews
Excellent idea. Great job. I wish I would have thought about tying the actuator to the rod. And, yes, without those diagrams from hooked, I would never have gotten it back together without pulling the steering wheel.
Old Jun 12, 2017 | 11:06 PM
Den14's Avatar
Den14
For further reference to removing the Multi-Function lever...The column must be in a neutral/straight position to pull the lever out.
Old Jan 1, 2019 | 03:33 AM
BLKMAMBA's Avatar
BLKMAMBA
I realize this is an old thread but hopefully I get a response. mine are stuck on high beam. (93) is there a way to jet get it to low beam and leave alone? I dont drive my car on the street often and if I do it is usually daytime. so I would like to just get to low beam and leave it there. thanks
To Dimmer switch rod actuator
Old Jan 1, 2019 | 08:45 AM
WVZR-1's Avatar
WVZR-1
The actual dimmer switch isn't a difficult reach with just the 'hush panel' removed driver side. I'd think a simple operation for you. Do you have the FSM?
Old Jan 1, 2019 | 10:40 AM
BLKMAMBA's Avatar
BLKMAMBA
Originally Posted by wvzr-1
the actual dimmer switch isn't a difficult reach with just the 'hush panel' removed driver side. I'd think a simple operation for you. Do you have the fsm?
fsm?
Old Jan 1, 2019 | 04:17 PM
whobub's Avatar
whobub
fsm?
fsm == Factory Service Manual
