Upgrades For '85 L98?
Old Mar 1, 2012 | 02:16 AM
tunedport85inject's Avatar
tunedport85inject
Yes John,my engine lately shows a little blu smoke puf when fired up,i know this simpthom is related to valve seals worn out,as you suggest, it's time to replace them.Again any issue if i use my NON-self aligning RR,engine is stock only with long tube.
Old Mar 1, 2012 | 02:40 AM
oldalaskaman's Avatar
oldalaskaman
dont forget to install the guide plates?
Old Mar 1, 2012 | 07:20 AM
tunedport85inject
Originally Posted by John A. Marker
...You do not need guide plates with iron heads, they are needed for aluminum heads. Self aligning RR would be best. You do not need to machine the stock head. You WILL HAVE to take the stock valve covers and grind off the drip tabs on the underside of the covers. Do not attempt to break the tabs off. Cut them with a small cut off wheel and then grind them down with a die grinder.
Just remove the bolt that holds the stamped rocker in place and remove the stamped rocker. Replace with the roller rocker and the new lock nut. Adjust the rocker as you would any rocker arm.
From past Forum posts, members have indicated that you would get 10-15 HP installing RR's. I am sure that number is dependent on what heads you have and the ratio you install.
John said that i don't need guideplates on cast iron heads,if you read my previous post,i was asking this about my cast iron heads,guideplates or not using self aligning,becouse of the cast bosses where rockers studs are pressed in...
Old Mar 1, 2012 | 09:52 AM
oldalaskaman
good deal, I saw non-self aligning and crs'd the rest.
