Rev Limiter
Old Feb 28, 2012 | 10:08 AM
ggroller's Avatar
ggroller
Default Rev Limiter
Hey All,
Is there a rev limiter on a 1992?
I was driving aggressively last night and the throttle was cutting in and out on me.
Old Feb 28, 2012 | 10:09 AM
Nathan Plemons's Avatar
Nathan Plemons
I don't remember the exact number but it's around 5800ish.
Old Feb 28, 2012 | 10:17 AM
383vett's Avatar
383vett
How much gas was in your tank?
Old Feb 28, 2012 | 10:19 AM
ggroller's Avatar
ggroller
I was on reserve.
Old Feb 28, 2012 | 11:15 AM
corvette Stu's Avatar
corvette Stu
Originally Posted by ggroller
I was on reserve.
There you go
I never let mine get below 1/4 tank. Did you ever change a fuel filter on one of these cars ? You will be doing it a lot if you keep running on reserve.
Old Feb 28, 2012 | 11:31 AM
ggroller's Avatar
ggroller
Originally Posted by red rock
There you go
Uh oh. I'll make sure I keep it above 1/4 tank from now on.
What happens when you run on reserve? What is reserve?
Old Feb 28, 2012 | 01:00 PM
Nathan Plemons
Nothing "special" about reserve. It's just when the fuel level gets to a certain point (maybe 2 galllons left?) it kicks on the reserve light.
Trouble is that the car accelerates fast enough that you can actually slosh the fuel away from the fuel pump intake. I've never heard of it causing fuel filter problems but the theory being that if you're running on reserve and sloshing it, you might be more prone to stirring up the trash and sludge that eventually accumulates at the bottom of the tank.
One thing that can be a problem is the fuel pump itself. The pump is an in tank design that is actually cooled by the fuel flowing through it and around it. If you get low enough that the pump starts sucking air it can shorten the life of the pump.
Old Feb 28, 2012 | 01:03 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Reserve = you're walking or you have 2 gal left.
Depends on your fuel level sensor.
I don't pay attention to mine at all, its how many miles I've gone or at the track it 5 gal at lunch and 5 gal in the AM.
Old Feb 28, 2012 | 01:18 PM
ggroller's Avatar
ggroller
Thanks, everyone, for the replies.
Old Feb 28, 2012 | 02:38 PM
c4cruiser's Avatar
c4cruiser
Hey All,
By "aggressively", you mean on the track, right?? The CF frowns on discussing or mentioning things like street racing or really excessive speeds on the street.
Yes,, the LT1 and LT4 C4's had a built-in rev limiter that kicked in at around 5850 RPM. IIRC, it was a fuel cut-off done by the ECM.
As others said, keep a minimum of 1/4 tank of gas in there. Always running fuel levels really low will wither burn up the pump or cause the pump to suck up stuff on the bottom of the tank. That will clog the "sock" on the bottom of the pick-up and will also clog the fuel filter.
Chances are the filter has not been changed either at all or for some time. It would be well worth changing the filter and pulling the pump to replace the sock.
Old Feb 28, 2012 | 02:46 PM
cv67's Avatar
cv67
St. Jude Donor '05
Try and keep some gas in the tank period, with any fuel injected car
That pump gets hot the only thing that keeps it cool is the fuel its submerged in. Run it low a lot and your pump will go south prematurely.
They are easy to change but who wants to pay for something if they can avoid it.
Old Feb 28, 2012 | 02:58 PM
Nathan Plemons
I'd say you're alright as you didn't give any details. Granted the car can easily exceed the speed limit of most highways in the country in 2nd gear..... maybe you were just playing on the interstate in 1st, yeah that's it.
Old Feb 28, 2012 | 03:16 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
I was on reserve.
Running around on reserve is a sure fire way to run out of gas.
It costs the same to run around on a full take as it does to run around on almost empty.
Old Feb 28, 2012 | 03:20 PM
Nathan Plemons
I like to keep mine full enough that if I do have some reason to punch it, it won't be an embarrassing experience.
I've never run out of gas but I've come DANG close. IE, my fuel pressure gauge was holding a not so steady 10 PSI as I limped up to the pump. Needless to say, I don't let it get that low anymore.
Old Feb 28, 2012 | 03:28 PM
ggroller's Avatar
ggroller
Yes, on the track. *cough*
The gauge went from 1/2 tank to 1/4 to reserve quicker than I expected.
When I filled up this morning I realized I was running on fumes. That would have sucked if I would have run out of gas.
Old Feb 28, 2012 | 03:47 PM
Nathan Plemons
Yeah, you can easily get 100 miles on the first bar of the gas gauge, depending on how you drive you may get 150-200 more out of the whole rest of the gauge.
Notice the bars get thicker as they go up?
Old Feb 28, 2012 | 04:32 PM
ggroller's Avatar
ggroller
No, I didn't notice. I'm going to pay much closer attention to this tank of gas.
To Rev Limiter
