Not to derail your thread but I heard you have some extensive background on Hydraulic throw out bearings.
I picked up a 91 black/red coupe with the 412 small block in it that fastlife had advertised here on the forum not long ago. He said the clutch was slipping at highway speeds in upper gears, I got the car and clutch pedal grabs about 1" from the top of its travel and its obviously something going on with this set up, slipping so bad that you can let the clutch out fully with a few rpms and it sounds like an automatic.
Pedal has a small amount of play all the way at the top so that's telling me the rod is returning.
I'm thinking the disc is cooked and as it wore, it brought the clutch fingers tighter and tighter towards the hydraulic TO bearing, eventually actually riding the fingers causing a diminished clamp from the pp making it slip.
Entire Ram Clutch set up including a Ram Flywheel custom made for the 400 sb is said to be not very old including the hydraulic TO bearing.
That sound about right to you? Have not pulled it apart yet was hoping maybe you could point me in the right direction with a fix before I tear into it....I think I've answered my own question but would like to hear your opinion.
Thanks,
Gibby
Is this for a ZF?, it could be lots of things, but when the pedal gabs high, your disc could be thin, the PP worn etc, no way to know definitively without pulling it out.
Thanks Larry, I'll let you know what I find when I dissect it.. It is a black tag ZF in the car.
Good luck with your new bullit, theres no substitute for cubic inches...
Most likely a single plane. It will give me a chance to make an elbow to work with the SC. I might make is specifically deigned to be fed directly by the SC if it makes sense, too early to tell now.
I'm looking up the steep money hill trying to figure out out to climb it
The Stealth Ram will go up for sale next winter/spring, along with the forged rotating assy I have, oil pan, cam, AFR heads etc,,,
You can keep most the "Highdollar" stuff on your car already and bolt right up to all your accessories and trans. Anyway, just food for thought. You could always source some used LS intake and heads or go with new bad-boys.
I would want new heads, I have the old style AFR's which did not flow worth kr@p, even after porting.
This will be an all new engine, clean sheet of paper, whatever direction I go. Out with the old!
It would be nice to stick with a SBC if possible, but I don't want anything less than 650HP, Maaaybe 625hp, however it happens, except No,,,Zero,,,Nada, NOS.
