Try again... 454 Motown shortblock
Old Mar 1, 2012 | 11:24 AM
rbates74's Avatar
rbates74
Default Try again... 454 Motown shortblock
MOTOWN II 4 bolt billet splayed cap block
9.025" Deck
Stock location Cam tunnel
Works with ALL 23 degree standard heads
4340 Eagle Crank, H Beam Rod/ARP Bolts
Mahle dish Piston for low compression Pump Gas/Boost
9.4:1 with 75cc chamber and .040 gasket
Arp Stud Kit,Total Seal Hellfire rings,Clevite H Bearings,Comp Cams Roller #12-470-8 Duration 252/252@.050, Lift .600/.600 on 110 and Cloyes Timing cover #9-221 Quick Change and Cloyes Hex-A-Just double roller chain. Invested $5600 with cam and parts, must sell, its all new short, never had heads on it/never run!
**Bore/Stroke: 4.250 x 4.000 = true 454cuin!!!!!
I serached out all the parts
block 2151
crank 689
pistons 609
rods 375
arp bolts kit 200
rings 240
cam 300
bearings 100
timing cover (ick) 130
timing chain 130
= 4924
all machine work all done professionally by World/Bill Mitchell Hardcore Racing Products. not sure what that and assembly would run
the cam seems far to big, and would require imidiate upgrade of many components
Old Mar 1, 2012 | 12:03 PM
rklessdriver's Avatar
rklessdriver
The cam sounds way to small for a 454 inch motor to me..... if your trying to make any HP anyway.....
Other than that the compresion is way to low for anything but a supercharged/turbo engine and if thats what your trying to do with it that camshaft is no where in the ball park.
Will
Old Mar 1, 2012 | 12:33 PM
rbates74's Avatar
rbates74
ya, plan to run 6 to 12 pounds of boost, 6 fopr now, 12 after I can get the upgraded pullies, so i will be doing a cam swap.
trying to pick this up for under 4 grand
Old Mar 1, 2012 | 12:56 PM
LD85's Avatar
LD85
Basically, its a short block right?
What cube are you after?
Old Mar 1, 2012 | 01:05 PM
rbates74's Avatar
rbates74
yes.
but its a forged 454 shortblock
it has all the parts I would have selected for myself (though im not real fond of eagle) and I would not have started with a 2 grand block or gone with that many cubes.
subtract the 2 grand block and the 300 cam, and you still have 2800 - 3000 in parts if bought new, depending on the block used.
plus machine work and assembly
I am trying to get him to come down to 3500.
IF i get it for that, its like i picked up the block, machine work, assembly and 71 cubes for $500-$800
Old Mar 1, 2012 | 09:03 PM
cv67's Avatar
cv67
St. Jude Donor '05
What kind of miles are on it?
Dont want to be a downer just know that block cant be bored. '
one time use then toss it.
Old Mar 1, 2012 | 09:48 PM
rbates74's Avatar
rbates74
no miles, its a brand new block and internals, asembled but then never even had heads put on it.
am probably going to buy it even at the asking price, id rather get it cheaper....... but...
just means it will take a little longer to get the supporting parts
Old Mar 1, 2012 | 11:50 PM
cv67's Avatar
cv67
St. Jude Donor '05
Ok well youll have cubes so far
just get an intake it can breath through time to sell the TPI stuff lol.
Old Mar 2, 2012 | 12:04 AM
rbates74's Avatar
rbates74
yes, i will need a mini ram.
im tempted to try and run it with my reworked stock heads and the edelbrock high flow... jsut so i can get it put in, instead of sitting in storage
Old Mar 2, 2012 | 12:37 AM
cv67's Avatar
cv67
St. Jude Donor '05
I woudnt.
Pistons it comes with will probably want a much larger chamber much bigger everywhere period. The intake....like peak at 2200rpm and its done. Plus your tune.
Know its tempting but with this one you should wait til you have it all together with the right parts. That mini will need some serious work done to it too. (porting)> That CI can handle a LOT of head/intake
It will be worth it though youll have a monster on your hands.
Sell the stuff you got and start bargain hunting
Old Mar 2, 2012 | 02:28 AM
rbates74's Avatar
rbates74
guy isnt coming down on price, but i found a similar set up with 434 cubes, i am bit nostalgic for the 454 number, but not enough to pay 800 for 20 cubes when my budget is so short
Old Mar 2, 2012 | 02:58 AM
cv67's Avatar
cv67
St. Jude Donor '05
Man you are alll OVER the place.
Out of control
Old Mar 2, 2012 | 03:43 AM
cv67's Avatar
cv67
St. Jude Donor '05
wow.
You need a distraction alright
Hang in there
Old Mar 2, 2012 | 05:12 PM
rbates74's Avatar
rbates74
WOOT guy came down to 3500, I am getting the 454!
its local pick up only, 12 hours away.... trying to get him to meet in the middle.
now it will sit, hmmm probably in my kitchen beside the super charger while i come up with money for heads and mini ram, have 500 left, so need about 2500-3000 more after things like gaskets, rockers valve covers ect
then a few hunded more for super charger plumbing, then 800 more for alchy injection
then 6 grand more for a car with a z56 and nicer paint......
hpwever, i doubt i can wait 3 years, so once i get the heads and intake, i may jsut try and run it at 8.4 compression, should still be pretty stout.
Old Mar 2, 2012 | 05:14 PM
LD85's Avatar
LD85
smoking dude!, I am right behind you with a Christmas time ATI Procharger build, thats a great deal, congrats!
12 hours to where, how far from INDY, maybe I could bring it half way for you.
Old Mar 2, 2012 | 05:35 PM
dan0617's Avatar
dan0617
Forget $800 for alchy injection....look up Mr Freeze from Anderson Ford Motorsport. $189, no electronic parts to fail, easy install, works beautifully. Only downside is the 2 quart tank needs refilling often, but I'm under my hood all the time anyway so no big deal for me.
Old Mar 3, 2012 | 09:24 PM
LD85's Avatar
LD85
what cam are you using?
To Try again... 454 Motown shortblock
Old Mar 3, 2012 | 11:29 PM
rbates74's Avatar
rbates74
I am probably going to start with the cam that comes with it as posted above. for cash reasons, I am told it reacts diferently in this combination then people expect, and if it dosent work then i will swap it out.
Id like help with the transportation, but it it in long island new york, not sure youd like to drive that far :P
my biggest concern at the moment is gas, not time, im a bit tapped :P
Old Mar 3, 2012 | 11:38 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youll be fine with it.
Right head on it youll make huge power everywhere.
No need for high revs you got the cubes.
Piston speed dont want too much of anyway. 6k and youre good Id imagine
Thats a popular drag race cam that supposely is easy on parts.
Old Mar 4, 2012 | 01:44 AM
rbates74's Avatar
rbates74
For a street engine .125 on the non thrust side and .170 on the thrust side. you can trade this for .156 to .160 all the wall around if you luck out with concentric walls.
If going over 6000 RPMs or racing .170 on the non-thrust side and .2 on the thrust side is safer. This also works if concentric at about .185-.190 all the way around.
High RPMs, nitrous, blower all require a thicker wall to hold the pressure and temperatures without distorting. A wall approaching failure will show cracks in the direction of the perimeter, usually forming near the deck or in the side wall lower in the cylinder at the point of greatest piston side thrust.
world says max bore is 4.200 leaves 2.00 wall minimum
so that means this block has 1.75 minimum now, not idea and over the limit set by world. adding nitro or boost may not be a good idea, I am going to call world products on Monday. he says bill at world did all the machine work and fitted the rods and crank, so hopefully they sonic tested it as well, we shall see, id rather have fewer cubes and not have to worry about it,
