Help. Opti spark installation question
Old Mar 2, 2012 | 03:27 PM
Mastr Fab's Avatar
Mastr Fab
Default Help. Opti spark installation question
My friend had his opti spark off his 93 Vette. It has the splined drive shaft. He wasn't sure how to reinstall the unit so he located TDC and aligned the rotor up with the center of the tip pointing to the terminal on the cap. the engine starts and idles but misses when reved up. What is the proper procedure for reinstalling the unit with the splined shaft?
Old Mar 2, 2012 | 03:50 PM
jispr's Avatar
jispr
It only goes in one way!! Look at the shaft, part of the splines are different, sorta like 1 spline is missing. That lines up with the same female part. If ANY effort was used to install the shaft, the drive shaft or the female part or both could be buggered beyond use. I'm sure you will get more responses but they'll want to know how the motor was running before and why the opti was pulled and is it new or used?
Miles on the opti?
Good luck!
Old Mar 3, 2012 | 05:21 PM
SJW's Avatar
SJW
If the Opti went back on easily (you didn't need to force it into place), it should be aligned correctly to the camshaft. If this is true, and the Opti is believed to be good, look elsewhere for the miss. Possibly a plug wire didn't get fully seated onto its tower on the Opti?
Live well,
SJW
Old Mar 5, 2012 | 03:09 PM
midweekwarrior's Avatar
midweekwarrior
check the opti pig tail connector
To Help. Opti spark installation question
By Michael S. Palmer | 2026-06-03 09:39:05
