C4
Old Mar 4, 2012 | 10:29 AM
jcgboys's Avatar
jcgboys
4th Gear
Default C4
Just inherited a 1984 C4 Corvette from a friend of mine, however, the car had been parked in his garage for several years. I am now attempting to turn it on and am not getting any fuel to the injectors. If I spray some starter fluid in the cavities I can get it to run for a few seconds and then it turns off. Any ideas?
Old Mar 4, 2012 | 10:34 AM
jhammons01's Avatar
jhammons01
Fuel pump has failed (very easy fix) Fuel filter is clogged.
Gas has turned to kerosene or worse gummed up....
Lift the fuel filler door on the back, and start removing hardware until you can pull the fuel pump out.....it lifts up straight and a 10mm will do....
if the injectors do not have adequate fuel pressure they won't fire.
Old Mar 4, 2012 | 10:39 AM
jcgboys's Avatar
jcgboys
4th Gear
Is the fuel filter sold together with the fuel pump? Or are they separate pieces? Any info is greatly appreciated.
Old Mar 4, 2012 | 10:50 AM
VetteMed's Avatar
VetteMed
separate parts.
Also, in the future, you'll get faster replies if the title of your thread reflects your question. using "C4" as the title tells other forum viewers nothing about whether or not it's worth their time to click on your thread. A better option would have been "1984 not getting fuel to injectors", for example.
Old Mar 4, 2012 | 10:52 AM
jhammons01's Avatar
jhammons01
Your filter is under and near the front wheel ......it is old school chevy....just look under where the jack points are and you'll see the fuel lines.
beware, folks jacking up the car sometimes will pinch the fuel lines.
Old Mar 4, 2012 | 12:39 PM
oldalaskaman's Avatar
oldalaskaman
and sometime they break floorboards, make sure you jack in the right sopt
Old Mar 4, 2012 | 01:47 PM
jcgboys's Avatar
jcgboys
4th Gear
Being that I'm a first time Corvette owner I will get better on the use of the forum to best describe what issues I am having on future post but I do appreciate all the inputs from all. Thanks and I will start with the fuel pump and fuel filter.
Old Mar 4, 2012 | 06:04 PM
blkvette85's Avatar
blkvette85
My '84 sat for a few years. I flushed the fuel system, replaced the fuel pump and filter. Still would not start. I had to tap the injectors with a screwdriver handle. Fired right up after that. Runs great to this day.
To C4
