i was thinkn of supercharging my 87 l98 vette.what head gaskets should i use? ALSO GOING TO JOD VALVE JOB.Cometics MLS where on the top of my list whatca think?
greg@blowerworks told me to use gm stock head gaskets.
He said they are more forgiving (if something got left behind on the deck surface).
The base model felpro's (not the blue-lined felpro 1074's for lt1) worked fine for me for a previous head swap I did 11 years ago.
Dont use the cometic gasket unless you are having the engine removed and the deck prepared especially for that one.
Id hate for you to end up with 'bubbles' in your coolant (from exhaust gases finding a pathway into the coolant jacket).
Finally,
Unless your goals are 800 HP, I wouldnt use head studs. These dont seal the holes as well (the holes go into your water jacket) and there is a tendency for coolant leaks to travel up the threads. Your supposed to use sealer on these, but some guys still have trouble. They also make it extremely difficult to removed the heads w/ the block in the car (so Im told).
