86 headlight module?
Old Mar 7, 2012 | 02:01 PM
2fas2c's Avatar
2fas2c
Default 86 headlight module?
for the life of me I can't find the headlight module? I was under the impression that 84-04 had a headlight module but on this 86' I can't find the darn thing. In the LH front inner fender I only find 3 relays with a cover? am I missing something here or did 84-87 not have these? HELP! I'm at my witts end trying to find this thing.
Old Mar 7, 2012 | 03:13 PM
2fas2c's Avatar
2fas2c
no one knows???
Old Mar 7, 2012 | 03:29 PM
3 pedals's Avatar
3 pedals
'84-'87 uses the relays that you found. '88-'96 uses a module.
Old Mar 7, 2012 | 03:36 PM
2fas2c's Avatar
2fas2c
thanks 3 pedals! you da man!
Old Mar 7, 2012 | 04:58 PM
2fas2c's Avatar
2fas2c
anyone know where I can get the headlight retro-fit kit?
Old Mar 7, 2012 | 05:13 PM
rodj's Avatar
rodj
Junkyard
Old Mar 7, 2012 | 06:31 PM
2fas2c's Avatar
2fas2c
what all do I need to do the swap? just the 2 wire motors? I already have the H/L module.
Old Mar 7, 2012 | 08:19 PM
rodj's Avatar
rodj
Harness from motors to the module with plug and the other plug with a pigtail to splice into existing wiring
Old Mar 8, 2012 | 12:56 PM
3 pedals's Avatar
3 pedals
The kit is no longer available new. Here is a link that has a pdf of instructions. http://www.mamotorworks.com/corvette...1-249-834.html
I haven't done the conversion yet - just bought a '93 hood with headlights and module.
Old Mar 8, 2012 | 04:06 PM
2fas2c's Avatar
2fas2c
ah yes, how could I forget
thank you sir!
Old Mar 12, 2012 | 02:32 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Are you convinced that you really need the retrofit kit? What's wrong with yours?
To 86 headlight module?
