Wrong oil used
Old May 16, 2002 | 09:25 AM
Redding's Avatar
Redding
Default Wrong oil used
I have only used Mobil One non-Synthetic but on the last oil change the dealer used Synthetic Mobil One. The car is an 87 only 43k miles. The car has driven less than 5 miles since the oil change.
What are my options?
Old May 16, 2002 | 09:33 AM
Rob90's Avatar
Rob90
Default Re: Wrong oil used (Redding)
Leave it in. Your car will love it :D
Old May 16, 2002 | 09:44 AM
Redding's Avatar
Redding
Default Re: Wrong oil used (Rob90)
I have read other postings and it sounds like if you want to change you need to do it when the milage is low otherwise you will have issues with leaking.
If it does leak what next.
Old May 16, 2002 | 09:48 AM
85 Dave's Avatar
85 Dave
:confused: ExxonMobil does not make a non-synthetic version of Mobil 1.
Old May 16, 2002 | 10:18 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I changed mine at 122K+ miles to Synthetic, after 3000 miles it doesn't leak anymore than it did with regular oil (one or two drops here and there when cold). If it starts to leak, find the leak and fix it. Most of the time its an easy fix (I need to pull the valve covers and replace the gaskets to fix my leak) or is something that needs to be done anyway (the valve guides and seals from what I've read wear out at high mileage).
And your engine will love it, mine seems to get to the power band quicker :D
Old May 16, 2002 | 11:27 AM
Redding's Avatar
Redding
Default Re: Wrong oil used (jaa1988)
Thanks for the posting I was a little concerned but feel must better after the earlier postings.
Old May 16, 2002 | 11:29 AM
FlyboyZR1's Avatar
FlyboyZR1
You should have been using synthetic to begin with. :smash: :crazy:
Old May 16, 2002 | 11:35 AM
ZylaRace's Avatar
ZylaRace
Leaking w/ Mobile 1, is an old problem. The early Mobile 1 formulations had this symptom. I have not heard of this for many years now.
Bottom line, I don't think you have much to worry about. You should be able to run longer between oil changes, with the One.
Old May 16, 2002 | 11:41 AM
VetteNoob's Avatar
VetteNoob
I started using Mobil1 at 84k. Doesnt leak a drop. My morning smoking (valve seal problem) has also stopped since the change to M1. Not sure of the 2 are related, but Im glad it stopped. Keep it in there.
Old May 16, 2002 | 01:30 PM
guywade's Avatar
guywade
it'll work fine, if you have a leak fix it! in an emergency you can even mix it no problem , i started using syn. at 54k no problems at all . :cheers:
Old May 16, 2002 | 02:34 PM
Rob90's Avatar
Rob90
85dave. Mobil makes oil called drive clean and its just plain old dino. I saw it a Autozone a couple of times :D
Old May 16, 2002 | 09:09 PM
abigfoot's Avatar
abigfoot
I was never a big fan of synthetic until I got my vetteand saw how clean the inside was. I will be changing all my vehicles over to it! :yesnod:
To Wrong oil used
