need some help please
Old Mar 12, 2012 | 04:17 PM
Hartzelly's Avatar
Hartzelly
5th Gear
Default need some help please
Ok i have a 96 c4, and i just got a full tune on it got just about everything done but when im at a idle and put the pedal to the floor it will cut out and try and die..but if im driving it and the rpm's are about 1800+ and i put it to the floor it will pick up and go fine any ideas of what this could be? ive been told fuel pump/distributor just thought i would get some other input on it. its driving me crazy
thank you
-zelly
Old Mar 12, 2012 | 04:28 PM
aminnich's Avatar
aminnich
Sounds more like a bad tune than anything else.
Old Mar 12, 2012 | 04:31 PM
Hartzelly's Avatar
Hartzelly
5th Gear
timing?
Old Mar 12, 2012 | 04:37 PM
Nathan Plemons's Avatar
Nathan Plemons
Ok, need to clarify exactly what you mean by "full tune." Do you mean you had somebody tune your computer for mods / performance, or do you mean you just had a "tune up" done, IE plugs and wires, fuel filter, etc. etc.
The Timing on an LT1 is completely computer controlled. If somebody has been jerking around in the computer and they don't know what they are doing, they could mess it up. If they never touched the computer and just did maintenance parts then it's not tuning.
Give us a little bit more information and we'll see where we can go from there.
Old Mar 12, 2012 | 04:45 PM
Hartzelly's Avatar
Hartzelly
5th Gear
ok yea it was just the basic plugs wires air/fuel filters pcv valve all fluids changed.. no one messed with the computer
Old Mar 12, 2012 | 05:05 PM
Nathan Plemons
Should not be a timing issue. Do you know what spark plugs they used? Sometimes that can make way more difference than you think.
The distributor on these is called the "optispark" and it gets blamed for a lot of problems. It has a fancy optical pickup in it but it has a cap and rotor just like any other distributor. Do you know if these were changed?
How many miles are on the car?
Old Mar 14, 2012 | 02:12 AM
Hartzelly's Avatar
Hartzelly
5th Gear
not sure what plugs they put in, but ill get them for sure and let ya know, the cars cap and rotor hasnt been changed and the car has 54k on it, im gonna go get the distributor tested tomorrow.. also i noticed today when in first gear and i get the rpms up to about 35/40k and just pin it, it was cutting in and out real bad wouldnt just ride through the gear.
Old Mar 14, 2012 | 04:35 AM
ddahlgren's Avatar
ddahlgren
What would make you think a 16 year old cap and rotor is still ok?
Old Mar 14, 2012 | 06:25 PM
Hartzelly's Avatar
Hartzelly
5th Gear
no idea, just never had any issues until it came out of the shop (strange)...
To need some help please
