ECU and constant fan operation
Old Mar 13, 2012 | 06:53 PM
J W Drew's Avatar
J W Drew
Default ECU and constant fan operation
My 85 C4 has a problem with the fan constantly running. My Corvette mechanic spent about 2 hours searching for wiring problems and came up with no problem. He has decided that the ECU is causing the problem. He also feels that someone has installed a high performance chip. So, he ordered a new ECU. I might mention the coolant temp. runs at about 165 tops and the oil temp. won't come on (150) for about 8 miles of freeway driving. I'm getting about 13 MPH. This C4 has the Z51 option. What do you think? Are we going in the right direction?
Thanks'
JW
Old Mar 13, 2012 | 07:29 PM
rodj's Avatar
rodj
Put a stop on the new ECM .
The tune for the engine is programmed onto the chip ,the chip that may be modified is removable
You only remove and replace that chip ;not the whole ECM.
Sort of like buying a new DVD player because you have finished watching one movie
Old Mar 13, 2012 | 07:37 PM
rodj's Avatar
rodj
Like as soon as you turn the key on before engine starts?
So he has confirmed the fan is being turned on only by the ECM?
No mechanical fan switches involved
Old Mar 13, 2012 | 08:40 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
My 92 does the same. As soon as key is turned on fan starts and does not stop until the key is turned off.
Old Mar 13, 2012 | 09:01 PM
J W Drew's Avatar
J W Drew
Yes the fan runs as soon as the key is turned on. No evidence the fan is hardwired or switched.
Old Mar 13, 2012 | 09:30 PM
rodj's Avatar
rodj
Both fans ?
Have you confirmed the fan is not hardwired or fan relay stuck in the on position?
A/c pressure switch working correctly?
Old Mar 13, 2012 | 09:32 PM
rodj's Avatar
rodj
Any codes showing on the computer?
A faulty memcal ( chip ) or it being incorrectly installed may cause fan to run
Old Mar 13, 2012 | 10:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check to see if the hi-pressure switch (smaller one) in the A/C pressure line is connected.
If so, pull the switch and short the two pins and cycle on/off the ignition switch to see if the fan stops.
Old Mar 13, 2012 | 10:52 PM
hitmanpty's Avatar
hitmanpty
My fan is the same. I check all the wireing and fix all in the driver side. I have to work on the a/c . Previous owner had make some wire change.
Old Mar 14, 2012 | 08:32 AM
Old Ben's Avatar
Old Ben
Originally Posted by rodj
Both fans ?
Only the main fan is running. I do not remember it doing it before I
had the A/C worked on a couple weeks ago. But then I have been having a few senior moments since I passed 66.
There was a very small leak where the piping connected to the canister. The mechanic said someone had apparently leaned on the piping, which is not secured anywhere, causing it to crack. Could they have not reconnected something.
Old Mar 14, 2012 | 10:26 AM
65Z01's Avatar
65Z01
In that case open the small connector in the A/C pressure line and jumper the contacts of the cable connector to see if this restores normal operation to your fan.
Old Mar 14, 2012 | 11:01 AM
J W Drew's Avatar
J W Drew
How does all this relate to my low oil and coolant temps as well as the 12.5 MPH?
Old Mar 14, 2012 | 11:05 AM
Nathan Plemons's Avatar
Nathan Plemons
It's very possible that the same person who minority engineered the fans to run all the time also installed a 160 thermostat.
As far as your 12.5MPH, try the pedal on the right.
I assume you mean MPG. If the engine is running too cold the computer will possibly never enter closed loop operation. Or even if it is in closed loop it will try to richen the mixture due to the low coolant temp. Kinda like driving a carb with the choke on all the time.
Old Mar 14, 2012 | 11:13 AM
Old Ben's Avatar
Old Ben
If the operating temperature is not reached then the computer will indeed make the fuel mix richer thus low MPG.
Old Mar 15, 2012 | 09:21 PM
Old Ben's Avatar
Old Ben
Is this the small plug at the canister by the firewall?
To ECU and constant fan operation
