bought a sbc 383 505 hp stroker on ebay. came with set up for a carb and hei.
the roller camshaft is a 110 centerline 567-577 lift 240/242 duration. the engine is stamped 14093638. i want to keep this system fuel injected.
please advise ! many thanks in advance !!!!
You could go with an HSR and use a TPI computer and aftermarket harness. You could also run TB injection. I had an HSR on my Vette and loved it. What is it going in? If its a TPI car you can use the old set up but it will be a restriction. Another alternative if you have TPI already is Large Tube Runners and a better or ported base and plenum.
please advise on all abbreviations and the set up cost on this . it is a 1992 corvette
Totally different ball game now.. There are people who have adapted the LT1 Intake to run a traditional distributor and use a remote thermostat. Hopefully there is a better answer for you.
thanks in advance again. the lt1 is coming out and the stroker is going in. please advise as far as proper intake. i apologise if im not grasping this as of yet.
what i want to do is take off the carb setup on the new stroker and replace with an aftermarket fuel injected system. is there another alternative?
No offense but are you doing the work yourself? It's more complicated than that. Is it going to be a race car?
There are a lot of aftermarket FI systems out there.
read this http://www.hotrod.com/howto/113_0504...s/viewall.html
the lt1 is coming out and the stroker is going in. .
Would have been a lot easier if you mentioned that at first.
Unlimited choice of EFI intakes for your engine but you have to consider how you are going to control the injection ; nothing will work with your '92 LT1 computer because no Optispark on your new Reg SBC
( would have been better to buy stroker LT1 engine ; a drop in fit to your car )
So as it stands you run the carb or get a different computer and wiring harness so you can run EFI
it is a 505 hp 383 stroker pulling old lt1 350 out the new engine has set up for carb and hei bit i want to keep fuel injected system . just need to know what is the most effecient way. yes most of the work myself until it gets too technical. thx again
I think what you are going to find is it is easy to make the new engine happy. I is the rest of the car that will suffer without the correct input.You may have to run 2 PCMs.
i understand . could you give me a starting point as far as a stock system in what vehicle year and all necessary info. just have to get this one running and will add aftermarket asap i have someone here who can tune it. they are specialist with corvettes. again many thanks
Since your present setup is a carb, just throw the new motor in and run it for a while. Spend some time and do some research and collect parts. Then when you are ready to swap out the carb for fuel injection, you will have the knowlege and the pieces to make it work. You could get the new motor running this weekend. My .02. Willie
i could you give me a starting point as far as a stock system in what vehicle year and all necessary info.
For ease ( being a relative word , what you need to do is major work )
you need the computer and engine bay wiring from a 90 -91 TPI car ;it being the closest to your 92
(and just because your computer looks the same you can't use it on anything except a LT1 engine )
As noted;
if you had bought a LT1 stroker , everything would have been a drop in fit . no mods needed.
What you are doing is a very hard expensive option to the point where I would just run the carb setup as is
or get a proper LT1 383 ;you already have the correct LT1 EFI manifold on your old engine
and the computer to run it
.......... It sounds like its already too technical for you ........ pull the guts out of the stroker ... ie , the rotating assembly and install into your existing LT1 block ... the cam won't fit the LT1 but they're not that expensive to replace ....... some Ebay deals aren't deals in the long run ... research before you buy ...............
