tach wire connector
Old Mar 17, 2012 | 12:38 PM
hitmanpty's Avatar
hitmanpty
Default tach wire connector
I can not find the tach wire connector on my 86 vette.
I was looking arrown the distributor cap but I dont see it. any information. in what harnnes this wire come out from???
pics will be great
Old Mar 17, 2012 | 01:56 PM
PAINTER MAN's Avatar
PAINTER MAN
It's a single brown wire coming from the back of the engine on the drivers side. The is a white snap connector on the end of the wire to connect to the distributor.
Old Mar 17, 2012 | 01:57 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's one of the connectors on driver side of dizzy, beside the battery connection. White wire, brown connector.
Old Mar 17, 2012 | 02:00 PM
PAINTER MAN
I think Agent 86 is right. I got the colors backwards.
Old Mar 18, 2012 | 03:46 AM
hitmanpty's Avatar
hitmanpty
Someone did a good job cutting that wire because i see no trace of tha wire. I will try to look for ti again tomorrow
Old Mar 18, 2012 | 04:09 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Do you find the tach filter bolted to the top of the bell housing?
Old Mar 19, 2012 | 02:52 PM
hitmanpty's Avatar
hitmanpty
in what side this suppost to be passeger or driver?????
Old Mar 19, 2012 | 03:05 PM
Nathan Plemons's Avatar
Nathan Plemons
Just from what I've seen of pictures of the car, I bet you don't find anything you're supposed to. It seems like the previous owner did a pretty good job of hacking it up. I wouldn't even bet on it being the correct distributor.
You're doing a great job trying to pull it back into shape, I don't envy you the task.
Old Mar 20, 2012 | 04:55 AM
Cliff Harris's Avatar
Cliff Harris
The tach filter is bolted to the top bell housing bolt on the driver's side (just put mine back on). It's too far down in the wiring harnesses to see normally. I saw mine because the transmission was out and the engine was tilted down in the back from its normal position.
Old Mar 20, 2012 | 08:11 AM
AGENT 86's Avatar
AGENT 86
Take a look at this pic, you can see my tach filter sitting on wiper motor. To the right, the dizzy connector and to the left, the harness connector and where the wire comes out of the rear loom. Save it and zoom in.
Old Mar 20, 2012 | 10:13 AM
hitmanpty's Avatar
hitmanpty
thank you........ you are good
Old Mar 20, 2012 | 10:22 AM
hitmanpty's Avatar
hitmanpty
one thing is for sure. Iam haven a lot of fun. reduing thi car. no rush
Old Mar 20, 2012 | 10:42 AM
Nathan Plemons
I understand that. For the past few weekends I've been working on getting my dad's old '46 pickup drivable. I ran into my fair share of BS and delays but ultimately I couldn't get mad, it was fun. Slightly frustrating at times but nothing to get angry over.
It's always so different when you WANT to work on something as opposed to HAVING to work on it.
Old Mar 21, 2012 | 09:33 AM
hitmanpty's Avatar
hitmanpty
Old May 11, 2012 | 10:29 PM
hitmanpty's Avatar
hitmanpty
I recall seen a black cable coming from that general area. but the cable is cut off. so I think I will have to get the rest of the cable and conector. I will try to take a picture tomorrow and post here just to make sure
Old May 12, 2012 | 04:26 AM
rodj's Avatar
rodj
Originally Posted by Cliff Harris
The tach filter is bolted to the top bell housing bolt on the driver's side .
Pics here
http://forums.corvetteforum.com/1562973606-post1.html
Old May 12, 2012 | 08:48 PM
hitmanpty's Avatar
hitmanpty
ok thankl you every one I fond. it is a black cable coming out of the back of the motor. it have the conector but after that is cut off.
I guest a new tach filter is in order
why will they cut off a tach filter??????
again thank you all
Old May 12, 2012 | 09:38 PM
rodj's Avatar
rodj
http://my.execpc.com/C4/4A/rodney1/corvette/
To tach wire connector
