L98 Engine Backfire
Old Mar 17, 2012 | 08:27 PM
Bredd1's Avatar
Bredd1
Default L98 Engine Backfire
After replacing two bad lifter in my engine, I got it reassembled and set the timing to 6*. When I drive or rev the engine to normal drive speed I get back firing in the engine. Is this do to the timing being off slightly. It seems to run good at idle. I have not set the idle air or TPS but I don't think either of these will effect the engine back firing. Am I on the right track?
Old Mar 17, 2012 | 09:08 PM
oldalaskaman's Avatar
oldalaskaman
valves to tight, or you didnt lap the valves, possibly crud sitting on a seat.
Old Mar 17, 2012 | 09:17 PM
Bredd1's Avatar
Bredd1
Valves too tight? When I set them, I tightened them til rod dragged, then went 1/2 turn.
Old Mar 17, 2012 | 09:25 PM
rodj's Avatar
rodj
Originally Posted by Bredd1
I have not set the TPS but I don't think either of these will effect the engine back firing. ?
TPS will;
it is only thing that tells the computer how far throttle is open so it can adjust fuel and timing to suit
If you have foot @ 50% throttle but TPS is only showing throttle 25% open
then you will have problems
Old Mar 17, 2012 | 09:49 PM
Bredd1's Avatar
Bredd1
Originally Posted by rodj
TPS will;
I will be sure to set the TPS, first thing. However I did not seem to have any problems with where it was set prior to replacing the bad lifters.
Old Mar 17, 2012 | 10:50 PM
bjankuski's Avatar
bjankuski
Check your plug wires to make sure you have the firing order correct.
Old Mar 18, 2012 | 12:27 AM
jfb's Avatar
jfb
Backfiring occurs when spark occurs with an intake valve open. Check timing. If you have a valve not seating properly, measure cylinder compression.
Old Mar 18, 2012 | 01:43 PM
Bredd1's Avatar
Bredd1
TPS will;
OK, I set the minimum idle air and the TPS. I'm still getting the backfire, I double checked the timing and it was slightly off by one degree so I got set to 6*. I'm going to pull my valve covers and set lash on the valves again, hopefully this will correct the problem.
Old Mar 18, 2012 | 02:04 PM
oldalaskaman
cheap test prior to pulling it apart is a compression check
Old Mar 18, 2012 | 10:14 PM
Bredd1's Avatar
Bredd1
Success, I got the backfire issue resolved, I went back through and reset the lash on all the valves and that corrected the problem. Now the engine runs smooth, almost perfect. Only issue I have now is I'm still hearing a ticking noise as I drive. Now that I've replaced the lifter, I can rule that out, either way it's not quite the same sound as I heard with the bad lifters. I can hear the injectors fire when I have the hood open but I wouldn't think they would be loud enough to hear when driving. Any ideas, I'm thinking it is something external from the engine. I can only hear it when I drive.
Old Mar 18, 2012 | 10:39 PM
Bredd1's Avatar
Bredd1
Another thought just remembered that when I was under the hood with the engine running I could feel pressure blowing at the EGR pipe when I revved the engine. Maybe the ticking sound is an exhaust leak. Would a leak at the EGR pipe cause the ticking noise when driving?
Old Mar 18, 2012 | 10:52 PM
oldalaskaman
I'd bet you're right, harbor freight sell a $4 mechanics stethescope that is money well spent
To L98 Engine Backfire
