Fuel filter
Old Mar 20, 2012 | 08:12 AM
C5nNC's Avatar
C5nNC
Default Fuel filter
My 91 will crank and idle but when i start to drive it dies and wont start back. If you let it sit it will crank and do the same. It has been in the garage for a few months.
I need to know the location and difficulty in changing the fuel filter. It may also be the battery which I had to charge before driving.
Old Mar 20, 2012 | 08:42 AM
Joe C's Avatar
Joe C
the fuel filter is located on the RH side frame rail near the starter. fairly easy maintenance item. best thing to do is is run a fuel pressure test. you should have around 38 psi. probably isn't a bad idea to change out the filter anyway. hope it isn't your FPR (PITA to get to on the L98).
Old Mar 20, 2012 | 08:51 AM
rodj's Avatar
rodj
Just down the page
http://forums.corvetteforum.com/c4-t...er-change.html
To Fuel filter
