Reset IAC via PCM
Old Mar 23, 2012 | 10:00 AM
jmgtp's Avatar
jmgtp
Default Reset IAC via PCM
I installed a 52mm throttle-body last night (a bored stocker). I haven’t fired it up yet and before doing so I’d like to reset the IAC.
I’ve used Freescan in the past on another OBD I GM car to successfully reset the IAC via the PCM.
My Corvette is a 94, which is still OBD I but it has the OBD II style connector. I have an AKM cable that connects to the ALDL and to the laptop via USB. I’ve had no luck in getting Freescan to connect using this cable (Freescan DOES support the 94 Y body). I believe the problem is that Freescan is looking for a serial port and the cable is USB. I used the cable once a long time ago, to reflash the PCM for when I changed the gears to 4.11s. I used a trial period of Tunercat (I had to buy the definition file).
So, how else can I reset the IAC via the PCM?
Any other Freebie software out there that connects? I have TunerProRT but I have it setup for another car and don't want to tweak the settings definitions (I struggle to get it back to where I had it). Besides, I'm not sure that TPRT can reset the IAC and I don't have the definition file for the Y body anyway.
Old Mar 23, 2012 | 10:13 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Not familiar with the LT IAC, but on my L98, the ECM will reset the IAC on the following start up.
Old Mar 23, 2012 | 05:30 PM
Road Agent's Avatar
Road Agent
From the 92 FSM. Not sure about the 94
Reset IAC valve pintle position:
A. Depress accelerator pedal slightly.
B. Start engine and release accelerator pedal, run engine for 5 seconds.
C. Turn ignition “OFF” for 10 seconds.
D. Restart engine and check for proper idle operation.
Old Mar 24, 2012 | 12:37 AM
Cliff Harris's Avatar
Cliff Harris
The PCM resets the IAC every time you shut off the ignition. That's why you have to wait 10 seconds to restart the engine. If your car does a MAF burnoff, it is also done during this time.
To Reset IAC via PCM
