carbing a 383
Old Mar 24, 2012 | 01:42 PM
c4vette85's Avatar
c4vette85
Default carbing a 383
So I just finished my 383 build and I am disapointed in the performace of the tpi intake. I know they dont flow very good and didnt want to put 1k into a intake. So im am putting a 750 vaccum secondary on my car. For the fuel pump I was just going to run a bypass regulator beacuse I only need 7-9 psi. Just making sure this will work and what regulator do you recommend?
Old Mar 24, 2012 | 01:50 PM
red L98's Avatar
red L98
I did it on my car a while back when i 1st built my 434 , I still have the regulator i used for my swap back then , I'd sell it to u if you like ..
http://www.summitracing.com/parts/MAA-4309/
Old Mar 24, 2012 | 02:26 PM
c4vette85's Avatar
c4vette85
Did you ever have problems with your return or did it work flawless?
Old Mar 24, 2012 | 02:49 PM
cv67's Avatar
cv67
St. Jude Donor '05
That carb will work fine on your 383. 300-36 Holley and Eddy rpm work well. May need a drop base air cleaner hood clearance will be tight!
Get specs from the mfr on height measure go from there.
Got a clean 750 DP with electric choke up for grabs....
Old Mar 24, 2012 | 04:37 PM
Crepitus's Avatar
Crepitus
There is about 9" from the block to hood. Using a carb without a choke housing, a Holley HP or mill the choke off a standard DP, will help a lot.
Old Mar 24, 2012 | 06:55 PM
red L98's Avatar
red L98
it depends how big of a Pump you have , and the size of the return line .. i used it with a walbro intank with a factory return line and it worked fine , but once i went up to a huge external pump / fuel cell and a -10 feed , i had to up the return line to a -8 or -6 ..
Old Mar 25, 2012 | 10:53 AM
c4vette85's Avatar
c4vette85
I just bought a holley 750 vaccum secondary with electric choke and a eldebrock intake for $100 off a buddy of mine. Cant beat that!
Old Mar 25, 2012 | 11:32 AM
c4vette85's Avatar
c4vette85
How much do you want for it?
Old Mar 25, 2012 | 12:31 PM
red L98's Avatar
red L98
i'll take 50$ shipped if ur in the US ..
Old Mar 25, 2012 | 07:56 PM
c4vette85's Avatar
c4vette85
PM me your address and ill send you the money this week. I trust you
To carbing a 383
