U-Joint PNs Needed - '92 Vert
Driveshaft, 2 Required: Spicer Series 1310 # 5-785X Non greasable
½ Shafts, 4 Required: Spicer Series 1350 # 5-799X Non greasable
THESE U JOINTS ARE FOR STEEL DRIVE SHAFTS!
Corvettes have aluminum drive shafts, these are aluminum compatible. Electrolysis may occur at the contact of dissimilar metals.
Manufacturer Drive shaft ½ shaft
Spicer 5-786X 5-800X
A/C Delco 45U0405 45U0400
NEAPCO (HI PERF) 1-0626BF 2-0617BF
NEAPCO (STD) 1-0153BF 2-0053BF
Rockford K153A & K467A* K178A & K447A*
*Check the numbers with supplier to verify will fit your application.
I'm betting I'm going to need the four 1/2 shaft U-joints.
I'm a little confused though. I'd like to buy the Spicer parts but not sure about correct PN. I don't know much about the steel vs. aluminum issue so I'd like to make sure I order the right ones.
