Engine Died While Driving
Old Mar 26, 2012 | 03:34 PM
red L98's Avatar
red L98
My car did that 10 years ago , it turned out to be a MAF .. The dry nitrous kit put a hurt on it ..lol
Old Mar 26, 2012 | 04:21 PM
84VetteMan205hp's Avatar
84VetteMan205hp
mine did that to but it would start right back up. but last time it did it was on the freeway but later on more like 4 years in oct of 2011. i found out that it was bad fuel lines
Old Mar 26, 2012 | 05:37 PM
Bredd1's Avatar
Bredd1
Problem solved. It was the HEI/ ignition control module. I replaced it and the car started right up. You guys hit the nail on the head with this one. Thanks everyone for your help. is there anything in particular that would cause this part to fail?
Old Mar 26, 2012 | 08:54 PM
caddyboy84's Avatar
caddyboy84
THE HEAT!!! or not enough grease I feel vindicated, too many people were leading down the wrong paths. The dialectric grease transfers the heat away from the part, the voltage regulator on these cars has it applied as well. Use a quality grease, I use CRC technition grade.
Old Mar 26, 2012 | 09:18 PM
Bredd1's Avatar
Bredd1
Thanks for your help Caddyboy, I used a good bit of dielectric grease when I installed the new one, I don't really know the quality of the grease but it was something they had at the parts store and the module came with a little packet of grease also.
Old Mar 26, 2012 | 09:23 PM
caddyboy84's Avatar
caddyboy84
Save that packet, ya never know. I think I'm a hoarder......
Old Mar 26, 2012 | 09:25 PM
LD85's Avatar
LD85
u da man!
