solid hub clutches
Old Mar 26, 2012 | 12:05 AM
ekess744's Avatar
ekess744
Default solid hub clutches
Is there anyone using a solid hub design on the street?
What are the biggest pros and cons of a sprung friction disc?
Old Mar 26, 2012 | 09:00 AM
VetteMed's Avatar
VetteMed
might help to mention what year / which manual transmission you are asking about.
In general, the sprung hub will be a little quieter and perhaps smoother on the street. In a ZF6 application, the dual mass flywheel allows for the use of a solid hub disc, since the dual mass is absorbing the vibrations and noise. When using a solid flywheel in front of a ZF6, a spring hub disc is suggested to help with that increase in noise/vibration due to the loss of the dual mass flywheel.
Old Mar 26, 2012 | 10:38 AM
TTOP350's Avatar
TTOP350
They can be used and I have before, I liked the feel better than a sprung hub but you can twist the splines off the input shaft a lil easier. Ask how I know.. LOL
Old Mar 26, 2012 | 12:34 PM
Zoui's Avatar
Zoui
The previous owner of my 2gen camaro installed solid hub clutch to it because the solid hub supposed to be "race". It was 100% PITA. I have driven cars with multi disc clutches, sprung sinter clutches, kevlar clutches you name it. But personally I totally HATE solid hub clutches in street car. You have zero advantage of using them and the amount of chattering and increased wear is just pita.
To solid hub clutches
