Hard start 94 LT1
Old Mar 26, 2012 | 06:23 AM
Nocrsis's Avatar
Nocrsis
Default Hard start 94 LT1
Car starts hard have to step on gas peddle when turning motor over. It has no codes, fuel pressure good doesn't drop any. Changed all sensors. Two different mechanic at dealership who specialize in vettes say coil windings. Currently have fuel rail & injectors at injector performance place getting checked for flow rates. Last summer same place did a sonic clean & flow rates checked on them any body have this problem before and are after market injector any good such as ACCELL
Old Mar 26, 2012 | 07:42 AM
Mohammed_z's Avatar
Mohammed_z
I'm interested to know , it happens to me only if I don't drive the car for two weeks or more.
1994 LT1
Old Mar 26, 2012 | 07:52 AM
Nocrsis's Avatar
Nocrsis
I left out the fact I'm referring to fuel injector coil windings
Old Mar 26, 2012 | 07:56 AM
Nathan Plemons's Avatar
Nathan Plemons
Most people who get aftermarket injectors go with the bosch III style. There are a few on here who have had luck with Accell but very few. Many others say they are prone to leak.
If your injectors are the problem contacr FIC, they will fix you right up. I'm betting though that it is not injectors.
Old Mar 26, 2012 | 08:33 AM
Nocrsis's Avatar
Nocrsis
Seems like when i had injector sonic cleaned & flow checked they would have found bad injectors but one injector did have different flow & they matched flow for all injector. Couple other people have said ECM needs to be flashed.at this just want to know what wrong and take care of it very frustrating.
Old Mar 26, 2012 | 12:04 PM
Nathan Plemons
It is most certainly best to have the proper size injector that the computer is expecting. The computer can compensate for small variances while the engine is running but during cranking it has no feedback. It can only assume that the injectors are correct.
Old Mar 26, 2012 | 12:21 PM
pcolt94's Avatar
pcolt94
Check the vacuum line of the fuel pressure regulator. See if it wet or dripping. If it is leaking back and filling the manifold with fuel, it will cause hard starting by being too rich.
You can have good fuel pressure and will run fine but the FPR can still be bad. Holding the pedel down on starting kills the injector pulses while cranking. So it may tend to start easier doing that.
Old Mar 26, 2012 | 02:54 PM
Nocrsis's Avatar
Nocrsis
Yes fpr vacuum was checked for fuel no fuel there. Kind of grasping for straws. Don't want to change injectors & that not be the problem. If I'm going to start replacing parts makes more sense to me to start looking at ECM first. right or am I wrong. Still waiting to get fuel rail & injectors back from shop. I'm kind of hoping there something wrong with with them, so I can fix problem. Kind of embarrassing have nice vette that starts like old Chrysler
Old Mar 26, 2012 | 07:08 PM
93Rubie's Avatar
93Rubie
How much are you stepping on the throttle pedal to get it to start?
1/4, 1/2, WOT?
What are the IAC counts while it has trouble starting up? Idle Air Control
On a electronically fuel injected car the IAC controls air at start up and idle. If it is sticking shut or close to shut, you could not be getting enough air into the engine to start it.
Old Mar 26, 2012 | 07:16 PM
Nocrsis's Avatar
Nocrsis
Not that much less than a quarter but will check that
Old Mar 27, 2012 | 02:12 PM
pcolt94's Avatar
pcolt94
Get a little technical. Connect a noid light on one of the injectors. Have a plug wire taken off (or get a in line spark tester) a with a screwdriver inserted, hold it near ground to test for spark. Have someone watch the noid light and for spark while the other person cranks the engine.
You might find a required input is missing at initial cranking.
Old Mar 28, 2012 | 09:57 AM
Nocrsis's Avatar
Nocrsis
Have bad news and goods new on hard starting 94LT1. Injector where flow tested at injector shop bad news all injectors drip. Good new I know what's wrong and now I can fix it. I will be calling fic. Thanks you Nathan plemons for info. Do you think that when they where sonic cleaned last year it did something to them?
Old Mar 28, 2012 | 10:13 AM
Nathan Plemons
I guess that depends on how and what exactly the shop did. Sounds like they weren't all that good.
Old Mar 28, 2012 | 10:30 AM
Nocrsis's Avatar
Nocrsis
Yeah I don't know what to think. Thought I was doing right thing having injector cleaned and flow matched when I had motor out. Motor did have little miss before I had injectors cleaned. O well more $ and it will be better dealership wants like $900 to $1000 I can get new injectors from FIC for $300 & something. Feel bad for people that can't do there own work.
Old Mar 28, 2012 | 10:42 AM
Nathan Plemons
Anybody who can't change the injectors on an LTx motor has no business driving anything. What is it, 4 bolts and 30 minutes with at least 2 beer breaks included?
Old Mar 28, 2012 | 10:52 AM
pcolt94's Avatar
pcolt94
That’s pretty strange having all the injectors leaking at the same time. If a couple leaked it probably would not affect the starting but all sure would. Engine was definitely loaded up on the start.
What kind of injectors were they?
Glad you found it. Who would have guessed.
Old Mar 28, 2012 | 11:22 AM
Nocrsis's Avatar
Nocrsis
I'm assuming stock original car has 62000 miles on it.
To Hard start 94 LT1
Old Mar 28, 2012 | 02:40 PM
Nocrsis's Avatar
Nocrsis
Yup
Old Mar 28, 2012 | 07:27 PM
93Rubie's Avatar
93Rubie
If that long, my goodness. Yup, leaking injectors that will cause a hard start. Fuel pressure gauge should have revealed this.
Old Mar 29, 2012 | 08:18 AM
Nocrsis's Avatar
Nocrsis
Yeah u would think so but it didn't it was describe to me as drip from injector shop. Must of been very slight drip. When I had motor out I was thinking about replacing injectors but when your repairing and replacing multiple things $ adds up fast. Thought cleaning and flow matching was just as good. So any body doing same thing save themselves $200 and replace injectors you can get Bosch type III for $320 Owell it only $ sometimes you learn the hard way
