1984 corvette
Old Mar 27, 2012 | 12:49 AM
Ttyson35's Avatar
Ttyson35
2nd Gear
Default 1984 corvette
I recently started work on my 84 vette it's been sitting for 5 years... I have basically got it up to par as far as the engine running but the one problem I have is the coolant fan... I am in the morning replacing the coolant fan relay switch basically my question is has any one replaced and re-wired this and had the fan still not kick on at 228 degrees ( temp at which it's programmed to turn on ) if it still will not come where would my next focus be?? The engine temp sensor?? Replacments made to engine coolant system: full engine and radiator flush, thermostat and gasket, radiator cap, and tomorrow coolant fan switch. Surely the motor to the fan hasn't went out because of the fact that the fan work perfect until I changed the spark plugs.... And I got to that damn 8th one one passenger side. I bumped the pigtail one the switch and cracked it while trying to tighten the spark plug. As well 2nd Q how the hell did you get that 8th plug tightened down??? Right now it is tight but not as tight as I would like ( used plyers on the conductor of the plug to tighten ) well if anyone has ideas or comment I would greatly appreciate hearing
Ttyson
Old Mar 27, 2012 | 12:59 AM
caddyboy84's Avatar
caddyboy84
Jump-out the a & b terminals on the OBDI connector and it should go right on, if it don't it could be the relay. If it does, go to the sender or it's connector. I'm pretty sure if you ground the connector wire it should go on as well, try that. If it goes on, it's the sender or how it's contacting.
Old Mar 27, 2012 | 01:09 AM
jhammons01's Avatar
jhammons01
Broke the sensor...replace and see what you get
The Spark plug is just a matter of using a swivel and extensions to reach and get a good turn on the thing.
Old Mar 27, 2012 | 03:23 AM
Hot Rod Roy's Avatar
Hot Rod Roy
Caddyboy, are you sure this will work on an '84? My factory '84 Electrical Shop Manual doesn't show this to be true (pg. 8A-149).
TTyson, Does your a/c work? The engine fan should come on when the a/c is on, because the fan relay gets a ground thru the a/c pressure switch on the compressor. The fan relay can also get a ground thru the temp switch on the pass. side head (between plugs 6 & 8). This wire on the fan relay is white.
Do you have 12 v. on both the red and the dk. blue wires on the relay (key on)?
If you have ground on the white wire and 12 v. on the red and dk. blue wires, the relay contacts should be closed, and you should have 12 v. on the blk/red wire to the fan.
I'll have to see jhammons do this to believe it! Changing the #8 plug on my '84 is such a tight fit I invented a special tool! I use a 1" long piece of 1/2" square tubing. This fits into my spark plug socket so I can put a 1/2" open end wrench on the piece of square tubing to turn the socket!
Old Mar 27, 2012 | 04:56 AM
caddyboy84's Avatar
caddyboy84
Yes it's true, your A/C will turn on your fan, but what if the A/C curcuit is problematic? Taking a paperclip from A to B will bypass any of that and let you know if the relay and fan motor are good. If they work, your next step is to ground the sesor wire, if THAT works the fan, then you know it's the sensor itself.
Old Mar 27, 2012 | 05:02 AM
caddyboy84's Avatar
caddyboy84
Default Huh?
I'm thinking the 88 and 84 are the same, I don't remember the 8 plug being such a big deal. I do remember the 8 plug being a bitch in my 88 Stang GT though. 2' extension, swivel??? I forget, but I just did them and I'd remember if it was a problem.Sometimes I'll use a 2 or 3" extension with 2 swivels and a 2 footer, almost like a tractor/trailer drive shaft.
Old Mar 27, 2012 | 10:04 PM
84VetteMan205hp's Avatar
84VetteMan205hp
i have an 84 and whoever wired my fan wired it so it turns on as soon as the key is turned to the on position
Old Mar 27, 2012 | 10:11 PM
caddyboy84's Avatar
caddyboy84
Not good if they bypassed the relay. I have a schematic that shows you how to wire both fans to operate together off the driver-side temp switch without bypassing the relays, I love that and want to do it, I just haven't had the time to read through it and wire it up.
Old Mar 27, 2012 | 11:46 PM
jhammons01's Avatar
jhammons01
I'm not sure what the issue is.....Mine was so uneventful My then 16yo Son that was in auto mechanics in High School did it for me while I supervised.
I may be wrong in the order or what exactly I used, but it was a 45 minute job plugs and new wires with new looms....
Old Mar 28, 2012 | 02:49 AM
Hot Rod Roy
Originally Posted by caddyboy84
I'm thinking the 88 and 84 are the same, I don't remember the 8 plug being such a big deal:
I haven't done the plugs on an '88, but I've sure struggled with the plugs on my '84!! The a/c unit is so close to the head you can hardly get your finger tips on the #8 plug! Even with my end-wrench-on-a-spark-plug-socket trick, it's tight! Another trick: Use a piece of rubber hose that fits on the spark plug insulator, about 12" long, to thread the plug into the head. Since the plug is so hard to reach, this really helps. I use the rubber hose trick all the time, so I don't drop a plug. Guide the plug with one hand while you spin the hose with the other hand.
FYI: the '84 has only one radiator fan. Lots of things not the same as your '88.
Old Mar 28, 2012 | 10:40 AM
caddyboy84's Avatar
caddyboy84
You reminded me of something, there is a brace on the back of the A/C that goes to the head that I remove before I do the right side plugs. That little bar that connects to the A/C bracket, remove it in a few seconds and it make things easier, sorry I forgot. P.S. Those little differences don't make for a different tune-up procedure, how does different fans make doing plugs different? Just tuned my friends 85, looked the same to me. Didn't notice the fan when I did the plugs, tps, air/idle.............For hard plugs I use a Snap-On curved handle/swivel-head 3/8" ratchet handle with a stubby extension and a deep 5/8" socket. On some cars, I've done plugs from underneath or through the wheel-well with the tire off or turned in.
Old Mar 30, 2012 | 01:18 AM
Ttyson35's Avatar
Ttyson35
2nd Gear
I got the fan working it was shorting its self out with a bad wire.. Replace wire... Problem solved. Next problem the tail lights do not come after turning head lights on. The turn signal work and the brake lights work but as far as having tail lights while driving down the rode they don't work.
Old Mar 30, 2012 | 02:38 AM
Hot Rod Roy
TTyson, we seem to have created a big fight over that #8 spark plug. What did you figure out? I hope you're not running the car with a loose plug!
Comments from other '84 owners would be appreciated.
Old Mar 30, 2012 | 10:09 AM
caddyboy84's Avatar
caddyboy84
Bad ground, check all bulbs and sockets then trace the wires. The grounds may have become rusty at the mounting points.
To 1984 corvette
