92 window motor replacement
Old Mar 29, 2012 | 02:50 PM
Brian Blum's Avatar
Brian Blum
Default 92 window motor replacement
Who has done it and how to do it.
Old Mar 30, 2012 | 03:42 PM
Brian Blum's Avatar
Brian Blum
Nobody.......
Old Mar 31, 2012 | 07:50 AM
LannyL81's Avatar
LannyL81
I have not had to replace a window motor but I can tell you that you will need to drill out rivets to get the window regulator out and of course use rivets to re-install. The rivets are large ones...1/4" diameter so you will need to either purchase or borrow a rivet gun with this capacity.
Also I think you have to remove the door glass....which is easy...and you will likely find the plastic guide is broken; $20 for replacement.
Not a difficult job to do....just have to be careful in removing all the parts. Should take you about three hours start to finish.
Good luck.
Old Mar 31, 2012 | 10:34 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
disconnect the battery
open the door
remove outer door panel
remove inner door handle
remove window glass
Drill out the rivets
use screws or huge rivets to secure the new one
put the glass back in and test, align it, etc.
put the rest together
To 92 window motor replacement
