85 corvette
Old Apr 2, 2012 | 05:28 PM
corvetebob's Avatar
corvetebob
Default 85 corvette
I have 85 CORVETTE with stock motor, I'm in the process of putting on 1989 stock aluminum heads and I will replace the runners with TPIS runners. Will I need to replace the stock manifold with an updated one? Don't know if the bolt pattern will effect this conversion.
Old Apr 3, 2012 | 12:49 AM
1986coupe's Avatar
1986coupe
You will also need to change your computer chip to get the right function with aluminum heads.
Old Apr 3, 2012 | 08:10 AM
blackozvet's Avatar
blackozvet
Hi Bob,
where did you get the runners from, are they new or second hand ?
The only difference you need to worry about first up is the 9th or cold start injector (which 85's are fitted with), do your runners have this provision ?
dont worry about the chip, the 85 computer and MAF can handle a lot of mods.
Old Apr 3, 2012 | 08:55 AM
Muffin's Avatar
Muffin
85 chip/ECM will do very well.
Old Apr 3, 2012 | 03:44 PM
corvetebob's Avatar
corvetebob
Hi Bob,
One from Ebay the other from AZ Speed.It does have the correct provison for the cold start. Will I need a new manifold?
Old Apr 3, 2012 | 04:32 PM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You can use your original base, but it will somewhat negate the affect of the bigger runners. Look into porting your plenum aswell.
Old Apr 3, 2012 | 05:54 PM
nutz4c4's Avatar
nutz4c4
Originally Posted by Paul Ruggeri
You can use your original base, but it will somewhat negect the affect of the bigger runners. Look into porting your plenum aswell.
Old Apr 3, 2012 | 07:23 PM
corvetebob's Avatar
corvetebob
I will be porting the manifold, plenum and the heads as well.
Old Apr 4, 2012 | 06:19 AM
blackozvet's Avatar
blackozvet
just port match the plenum and manifold to the runners and dont forget the gaskets too
To 85 corvette
