LT1 valvecover bolt kit PN?
Old Apr 2, 2012 | 10:39 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default LT1 valvecover bolt kit PN?
4 bolts that hold it down with rubber gasket.
Base gasket come with the kit?
Old Apr 3, 2012 | 06:41 AM
toptechx6's Avatar
toptechx6
LT1's used a couple of different covers, bolts and gaskets were different as well. depending on the year. 92's used a magnesium cover which uses gaskets Part # 14088564(1) Fel Pro VS50088 (2), most aftermarket covers will also use these gaskets. Bolts for those covers should be part number 10068165.
93 and later cars use composite valve covers that take a different gasket. Part # 10108625, bolts for the later covers are PN 10108675, but also require studs PN 10108674 and grommets, PN 10108626
I don't think there is a "kit" that includes all the correct parts from GM, perhaps Fel Pro can supply it.
Hope that helps.
