steering column movement
Old Apr 4, 2012 | 02:03 PM
petrov83's Avatar
petrov83
Default steering column movement
I have a slight problem with my steering column on my 96 which I am trying to solve. When you push down on it it has some play from the tilt joint. What parts must I replace in order to solve this problem? I can't figure out what is worn out. Is it the spring are those metal bushings on the sides? It seems like the left hole where the bushing goes in is slightly warped. Any place where I can order a full kit? Maybe with better parts?
Old Apr 4, 2012 | 03:55 PM
summerst's Avatar
summerst
Start here.
http://forums.corvetteforum.com/c4-t...made-some.html
I believe that this is one of the top ten topics of this forum. Just do a search and you will see.
