more 383 build questions...
If you're building a 355, the stroke is 3.48. You typed 3.75 -- which is for a 383.
I built a 383 with zero deck and .040 quench (e.g., .040" cometic head gaskets) Using the Kelley calculator, The SCR is about 10.25 with 8.25 DCR (my cam is similar to the LPE219 though a bit smaller. I used 20cc inverted domes with 58cc chambers.
With 64cc chambers, zero deck, and .040 quench, a 350 (355) can run flatter pistons (something around 5cc reliefs). Under this scenario, you'd have 10.36:1 SCR with 8.1 DCR. This is completely doable and probably what you'll find most people will recommend.
4cc reliefs are also fine.
If you deck it less, use a thinner gasket. Try to keep .040ish quench.
Really, you'd have to mill the (64cc) AFR heads (using flat-tops) to get too much compression on a 350 build.
http://www.lingenfelter.com/sites/li...mationv1.3.pdf
Also, when using the calculator, fill in tab 2 (cam specs) first. That provides cam closing for tab 1.
If you redo the specs with an advanced cam installation (e.g., 108ICL or 4-deg adv on the timing set), your compression will go up. The comments in the post above related to a SR cam installed at 112ICL. (straight up).
