line lock
Old Apr 11, 2012 | 08:36 AM
calvette 11's Avatar
calvette 11
Default line lock
Hi
I need some help installing a line lock on my 93.If some body has installed one.Where did you mount,the solenoid? I have bought a summit line lock unit,with the adapted fittings
Old Apr 11, 2012 | 01:12 PM
383vett's Avatar
383vett
Old Apr 11, 2012 | 04:11 PM
calvette 11
Default line lock
did you have a abs on your car?
Old Apr 11, 2012 | 08:06 PM
93Rubie's Avatar
93Rubie
383vett has an 84 so NO ABS.
However, line locks still work with ABS. Install the unit in the rear line after the master cylinder but before the ABS. You can mount the unit anywhere that is convenient. Note I do believe the unit has SAE double flares/threads? The Corvette has ISO bubble flares/metric threads, I think.
http://www.racespecialtydesigns.com/...&cat=56&page=1
To use:
Take ASR off
Apply Brakes, hit switch
Let of brakes, pressure held in rear brakes only.
Burnout.
Hit switch to release rear held pressure.
In fact, if you could change the programming of the ABS unit, the unit itself could act as a line lock. The unit has solenoid valves that can hold, apply via pump, or release pressure.
Old Apr 12, 2012 | 07:28 AM
calvette 11
Default line lock
The abs is in the rear compartment on this model.I have the fitting for the master cylinder and the abs.I got these from summit.The instructions said run a line from the rear of the master cylinder to the abs.That line would have to be over six feet long.my car is a 93,there is no room,like yours.
To use:
Take ASR off
Burnout.
Old Apr 12, 2012 | 05:20 PM
TA's Avatar
TA
Old Apr 12, 2012 | 09:55 PM
calvette 11
Default line lock
Does this car have abs?
Originally Posted by TA
Old Apr 12, 2012 | 10:58 PM
93Rubie's Avatar
93Rubie
Originally Posted by calvette 11
It is a 91, all Corvettes after 86 have standard ABS.
Like I said, mount right off master cylinder as pictured above. Rear line off master, install line lock solenoid inline with this line. No need to run any more lines. You are just splicing in, putting it inline with existing rear brake line off master cylinder.
Old Apr 13, 2012 | 07:19 AM
calvette 11
Default lock
I will do this on Monday.It looks like you have the front valve on the master cylinder hooked to the line lock unit.The front brakes run off the back,right?
=93Rubie;1580542007]It is a 91, all Corvettes after 86 have standard ABS.
Like I said, mount right off master cylinder as pictured above. Rear line off master, install line lock solenoid inline with this line. No need to run any more lines. You are just splicing in, putting it inline with existing rear brake line off master cylinder.[/QUOTE]
To line lock
