no interior light
Old Apr 11, 2012 | 02:38 PM
hitmanpty's Avatar
hitmanpty
Default no interior light
Ok since i got my car none of the interior light work. the dash is ok Iam talking about the ilumination light s like door cortesy light. and the side pole lights.
like to know where to start. first thing come to mind is fuse. but I dont know wich is the fuse.
open for repplys
Old Apr 11, 2012 | 03:09 PM
caddyboy84's Avatar
caddyboy84
open for repplys
I just got schooled on this very topic. If the fuses are good, it may be the light timer thats taped to the harness up by the heater-core area.
Old Apr 11, 2012 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
CLK/CTSY fuse
Old Apr 11, 2012 | 03:35 PM
hitmanpty's Avatar
hitmanpty
Light timer. any picture of that.???? how do I go about checking this
Old Apr 11, 2012 | 03:38 PM
hitmanpty's Avatar
hitmanpty
Originally Posted by AGENT 86
CLK/CTSY fuse
I find out during my time here on the forum. that 90% of the time your advice is the best. but I find very dificult to traslate your english to spanish.
let see
CLK = check
CTSY= dont know what this stand for..
fuse= this one is easy. fuse is fuse.
can you explain a little more about CTSY
Old Apr 11, 2012 | 03:53 PM
hitmanpty's Avatar
hitmanpty
ok I just find this link
http://forums.corvetteforum.com/atta...epair-ncrs.pdf
Old Apr 11, 2012 | 04:07 PM
hitmanpty's Avatar
hitmanpty
let asume. that the problem is the light timer.
is there any way to by pass this.just by tiding the wires or something???
Old Apr 11, 2012 | 04:19 PM
caddyboy84's Avatar
caddyboy84
Make sure it's not the fuse before you go hunting for the timer, but if it is the timer, you bypass it by splicing together the three white wires.
Old Apr 11, 2012 | 04:35 PM
hitmanpty's Avatar
hitmanpty
thanks I will check everything before to get to that point
Old Apr 11, 2012 | 04:38 PM
caddyboy84's Avatar
caddyboy84
AGENT86 gave me this info the other day. My lights and trunk went out and were out for a month, then they just started working all of a sudden. Could just be a loose wire at the timer if it's not the fuse.
Old Apr 11, 2012 | 05:43 PM
AGENT 86's Avatar
AGENT 86
let see
CLK = check
Clock/Courtesy fuse. On the fuse panel, it is written CLK/CTSY.
Old Apr 11, 2012 | 06:04 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
if it was that fuse, the radio would not work
Old Apr 12, 2012 | 01:50 AM
Cliff Harris's Avatar
Cliff Harris
CLK/CTSY also fuses the cigarette lighter and the electronic A/C controller. The courtesy light module also allows the rear hatch to be opened by the door switches (but only when a door is open).
15A (blue - azul to you ;-). Since I just replaced one, I know it's in the top row in the fuse panel.
Old Apr 12, 2012 | 09:09 AM
hitmanpty's Avatar
hitmanpty
ok I got it I will check the "CLK/CTSY" to night when I get home. hope that is the problem.
Old Apr 12, 2012 | 03:22 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
My interior lights also did not come on and the hatch would not open when I first bought my 92. The problem that I had was that the door ajar switches were bad in both doors. Replaced them and lights and hatch work fine.
Check your FSM for the method to remove the switch. On the 92 there is a backer plate that will fall off if you remove both screws.
Old Apr 12, 2012 | 08:24 PM
hitmanpty's Avatar
hitmanpty
ok I found the problem. more like AGANT86 found the problem. yes it was a burn fuse.
I change the fuse and all the light turn on.
but now the lights on the roof pilar. they stay on for ever.
the door cortesy light will turn off after a minute or so. but the other lights stay on.
I dont have a light under the dash yet. I have to install those.
but why the 2 pilar lights stays on all the time????? any idea
Old Apr 12, 2012 | 10:20 PM
AGENT 86's Avatar
AGENT 86
The cargo lights are also controlled by the switch at hatch latch. Have a look at the switch and the pin the contacts it.
To no interior light
Old Apr 12, 2012 | 11:38 PM
hitmanpty's Avatar
hitmanpty
where exactely this switsh is located
Old Apr 13, 2012 | 12:07 AM
hitmanpty's Avatar
hitmanpty
dont worry I know where it is
Old Apr 13, 2012 | 12:47 AM
hitmanpty's Avatar
hitmanpty
ok you were right again AGENT86 I check the hatch switch the switch is there ok and working ok. but the problem is the window lock.dontknow how to say so <i took some pictures. here they are.
you can see switch in this pic
[IMG][/IMG]
this is the window side you can see there is a part missing
[IMG][/IMG]
now you can se that the window is no tmaking contact with the switch
[IMG][/IMG]
