Head Gasket replacement
Honestly though the only other things that I can think of that you should check would only involve other problems your engine has. for example, you could clean the throttle plate or just replace all the seals in the engine.
"While you're at it"....is solely dependent upon budget. Something easy and for durability would be to replace the valve springs. Another thing would be to replace the lifters. A few horsepower can be gained with the addition of roller rockers. A few more horsepower can be gained by adding 1.6 roller rockers and having the heads machined to accept springs that will work with them. Yet more power can be gained with basic cylinder head porting, chamber clean-up, and port matching to the intake. Next up would be adding Super Ram intake manifold. etc, etc, etc.
How fast you want to go? How much money do you have?
Btw...A Factory Service Manual is a WISE investment. Buy one if you don't already have one.
By "While I'm at it," I simply meant maintenance and preventative things. I'm a college student that just bought a house, I have no budget
I'll keep this post in mind for future reference though
If you need guides, seats, valves, the price will increase. A cheap way to address worn guides is for the shop to knurl them.
In all likelihood, yours won't need anything more than cleaning/checking/surfacing.
Another $100 gets a valve job. If I supply springs, keepers, etc. they will do those at the same time they do the valve guides.
1) label each hose and wire that you take off without exception. Take pictures or make drawings to be sure where the parts came from. Place bolts in plastic bags with labels keeping them together as a unit.
2) label the bolts.....some are shorter than others on the runners to the intake.
3) ALWAYS use anti-seize on any steel bolt that threads into aluminum.
4) Use a center punch and dimple the china wall at the front and rear of the block. I also dimpled the intake manifold in these same areas. The dimples give the gasket material (Silicone or The Right Stuff) something to grab hold.
5) Use the Right Stuff instead of silicone.
6) I usually line up the timing marks before taking things apart. It makes it easier to tell where your distributor rotor should be pointing. Mark the position of the rotor.
7) You need to get some rubber push over plugs to cap off your fuel lines. They WILL LEAK if your don't (ask me how I know...
).8)
....drain the block by pulling the knock sensor and then the drain plug on the drivers side. These holes sometimes rust over, if so then use a screw driver to break thru the rust....be ready for rushing coolant.9) Use thread sealant on the head bolts. Suggest you use the same on the intake bolts where they enter the head if they will be exposed to oil from the galley.
10) While you have the TB/plenum and runners off clean the inside of carbon build up.
11) Take a cardboard box and punch small holes (or slots) in it to represent the each head marked front and drivers/passengers side. Then as you take out the push rods and rockers push the rod into the hole in the box to keep them in the exact position they came out of the heads. Then place the rocker over the rod.
12) Make sure that all your gasket surfaces are clean and oil free before assembly.
13) MAKE YOU DAD DO ALL THE WORK AS YOU GO FETCH BEER FOR THE TWO OF YOU....
GOOD LUCK ON YOUR PROJECT.
