91 vette wont start
Old Apr 18, 2012 | 07:03 PM
Mike Covello's Avatar
Mike Covello
2nd Gear
Default 91 vette wont start
Ok first time on the forum I have a 91 corvette turns over getting spark, getting pulse to the injectors but wont start. it was running rough parked it for a couple of days when I went to work on it I could not get it to start dont know what to look for next
Old Apr 18, 2012 | 08:03 PM
pcolt94's Avatar
pcolt94
Check the fuel pressure.
Can you here the pump run for 2 seconds when you turn the key to ON. Maybe the pump is dying or there might be a flow restriction.
Are you getting a good 1/2 inch spark right spark when sparked to ground?
Old Apr 18, 2012 | 08:17 PM
summerst's Avatar
summerst
Do you have a can of starting fluid? Have you tried it? Have you ruled out the injectors? If not, check them with an ohmmeter.
Old Apr 18, 2012 | 10:42 PM
Mike Covello
2nd Gear
fuel pump is new and I can hear it run when I turn the key on. I will try the starting fluid next, then I will check fuel pressure and the injectors next. Thank you for the help.
To 91 vette wont start
