85 and 87 climate control
Old Apr 20, 2012 | 02:36 AM
Pizzano's Avatar
Pizzano
Default 85 and 87 climate control
Could someone verify if the climate control panel/module if you will, is the same for 85 or 87.
(Controls under the stereo for ac/heat /fan)
Old Apr 20, 2012 | 09:24 AM
Muffin's Avatar
Muffin
They are not the same. 85 is pure mechanical, slide switches, and vacuum distribution valves. 87 is more electronic/digital.
Old Apr 21, 2012 | 12:00 PM
SunCr's Avatar
SunCr
Electronic and Manual are different beasts with Electronic being an option - but so are Electronics for convertible and coupe and with and without heated mirrors. As far as I know, Electronic Panels are out of production but vendors do offer rebuild services which is what I'd choose. The likelihood of a used unit failing - if it hasn't all ready - would be fairly high.
To 85 and 87 climate control
