c4 wont start
Old Apr 21, 2012 | 11:21 PM
petrov83's Avatar
petrov83
Default c4 wont start
My 96 c4 wont start, I get the brake pressure light on when I try to start and the engine wont turn over. Aghhhh...
Old Apr 22, 2012 | 10:04 AM
petrov83's Avatar
petrov83
Brake pedal is firm and fluid is where it is suppose to be.
Old Apr 22, 2012 | 11:13 AM
94z07fx3's Avatar
94z07fx3
I think you should be able to start the car even if every part of the brake system is failed. Put the brake light aside for a minute.
Test the clutch safety switch (manual) or try starting in neutral (auto).
Forum search for VATS troubleshooting. Clean the contacts on your ignition key's pellet.
Old Apr 22, 2012 | 12:26 PM
Black89Z51's Avatar
Black89Z51
Suckin' gas, haulin' ass.
What is the battery voltage?
Old Apr 22, 2012 | 12:47 PM
petrov83's Avatar
petrov83
the battery is fine, I did replace the clutch slave and master cylinders however, I am having trouble bleeding them out. Could that trigger some safety sensor so the car wont start?
Old Apr 22, 2012 | 12:51 PM
94z07fx3's Avatar
94z07fx3
There is a switch on the clutch to make sure it is full down prior to start. Make sure the switch is still in contact with the clutch pedal lever and that it is still connected and working.
Old Apr 23, 2012 | 08:05 AM
petrov83's Avatar
petrov83
The car wouldnt start because when I put the slave and master cylinders I forgot to take the aluminum bracket from the old master cylinder, everything is working perfectly now, system bled and the car starts.
To c4 wont start
